ECU codes final table (excluding 1999)
Old Mar 29, 2004 | 12:44 PM
Ted_MEng's Avatar
You need 2nd group of 4 digits to decode blinking MIL (CEL). 1st is used by Consult.
________________________
ALPHABETICAL INDEX FOR DTC
Items
*COOLANT T SEN/CIRC P0125 0908 EC-146
ABSL PRES SEN/CIRC P0105 0803 EC-118
A/T 1ST GR FNCTN P0731 1103 AT-96
A/T 2ND GR FNCTN P0732 1104 AT-101
A/T 3RD GR FNCTN P0733 1105 AT-106
A/T 4TH GR FNCTN P0734 1106 AT-111
A/T COMM LINE P0600 0504 EC-316
A/T DIAG COMM LINE P1605 0804 EC-425
A/T TCC S/V FNCTN P0744 1107 AT-123
AIR TEMP SEN/CIRC P0110 0401 EC-127
ATF TEMP SEN/CIRC P0710 1208 AT-86
CAM POS SEN (PHASE) P0340 0101 EC-251
CLOSED LOOP-B1 P1148 0307 EC-329
CLOSED LOOP-B2 P1168 0308 EC-329
CLOSED TP SW/CIRC P0510 0203 EC-311
COOLANT T SEN/CIRC P0115 0103 EC-133
CRANK POS SEN (REF)*3 P1335 0407 EC-338
CRANK P/S (POS) COG P1336 0905 EC-343
CRANK POS SEN (POS) P0335 0802 EC-244
CYL 1 MISFIRE P0301 0608 EC-236
CYL 2 MISFIRE P0302 0607 EC-236
CYL 3 MISFIRE P0303 0606 EC-236
CYL 4 MISFIRE P0304 0605 EC-236
CYL 5 MISFIRE P0305 0604 EC-236
CYL 6 MISFIRE P0306 0603 EC-236
ECM P0605 0301 EC-320
EGR SYSTEM P0400 0302 EC-256
EGR SYSTEM P1402 0514 EC-360
EGR TEMP SEN/CIRC P1401 0305 EC-355
EGRC SOLENOID/V P1400 1005 EC-350
EGRC-BPT VALVE P0402 0306 EC-265
ENGINE SPEED SIG*4 P0725 1207 AT-93
EVAP PURG FLOW/MON P1447 0111 EC-389
EVAPO SYS PRES SEN P0450 0704 EC-295
EVAP SMALL LEAK P0440 0705 EC-274
EVAP SMALL LEAK P1440 0213 EC-367
FR O2 SE HEATER-B1 P0135 0901 EC-185
FR O2 SE HEATER-B2 P0155 1001 EC-185
FRONT O2 SENSOR-B1 P0130 0503 EC-151
FRONT O2 SENSOR-B1 P0133 0409 EC-170
FRONT O2 SENSOR-B1 P0132 0410 EC-164
FRONT O2 SENSOR-B1 P0131 0411 EC-158
FRONT O2 SENSOR-B1 P0134 0412 EC-179
FRONT O2 SENSOR-B2 P0153 0413 EC-170
FRONT O2 SENSOR-B2 P0152 0414 EC-164
FRONT O2 SENSOR-B2 P0151 0415 EC-158
FRONT O2 SENSOR-B2 P0150 0303 EC-151
FRONT O2 SENSOR-B2 P0154 0509 EC-179
FUEL SYS LEAN/BK1 P0171 0115 EC-220
FUEL SYS LEAN/BK2 P0174 0210 EC-220
FUEL SYS RICH/BK1 P0172 0114 EC-226
FUEL SYS RICH/BK2 P0175 0209 EC-226
FUEL TEMP SEN/CIRC P0180 0402 EC-232
IACV/AAC VLV/CIRC P0505 0205 EC-305
IGN SIGNAL-PRIMARY P1320 0201 EC-331
INHIBITOR SW/CIRC P0705 1101 AT-82
KNOCK SEN/CIRCUIT P0325 0304 EC-241
L/PRESS SOL/CIRC P0745 1205 AT-130
MAF SEN/CIRCUIT*3 P0100 0102 EC-111
MAP/BAR SW SOL/CIR P1105 1302 EC-322
MULTI CYL MISFIRE P0300 0701 EC-236
NO SELF-DIAGNOSTIC FAILURE INDICATED No DTC Flashing*5 EC-54
OVERHEAT — 0208 EC-433
O/R CLTCH SOL/CIRC P1760 1203 AT-148
P-N POS SW/CIRCUIT P1706 1003 EC-428
PURG CONT/V & S/V P1493 0312 EC-412
PURG CONT/V S/V P1492 0807 EC-418
PURG VOLUME CONT/V P1444 0214 EC-377
PURG VOLUME CONT/V P0443 1008 EC-284
REAR O2 SENSOR P0137 0511 EC-190
REAR O2 SENSOR P0140 0512 EC-210
REAR O2 SENSOR P0139 0707 EC-204
REAR O2 SENSOR P0138 0510 EC-197
RR O2 SEN HEATER P0141 0902 EC-215
SFT SOL A/CIRC*3 P0750 1108 AT-134
SFT SOL B/CIRC*3 P0755 1201 AT-138
TCC SOLENOID/CIRC P0740 1204 AT-119
THRTL POS SEN/CIRC*3 P0120 0403 EC-138
TP SEN/CIRC A/T*3 P1705 1206 AT-142
TW CATALYST SYS P0420 0702 EC-270
VC CUT/V BYPASS/V P1491 0311 EC-407
VC/V BYPASS/V P1490 0801 EC-402
VEH SPD SEN/CIR AT*4 P0720 1102 AT-90
VEH SPEED SEN/CIRC P0500 0104 EC-301
VENT CONTROL VALVE P1446 0215 EC-384
VENT CONTROL VALVE P1448 0309 EC-396
VENT CONTROL VALVE P0446 0903 EC-290
Old Mar 29, 2004 | 12:49 PM
Kevlo911's Avatar
Kevlo for President
Space It Out!!
shilov
Feb 19, 2024 09:40 PM
Mar 12, 2020 12:06 AM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
220k+ A32
Sep 22, 2015 03:08 PM
jchronis2552
Sep 21, 2015 05:52 AM
