CEL code 0705 Evap Control Sys
Old Apr 2, 2004 | 05:03 AM
AusFlt's Avatar
Guys,
This is the third time that I have seen this code. The first time I tried replacing the valve on the canister(Rear wheel well) and managed to hack it all to pieces. So I had to get a new box. The second time I replaced the whole thing with one off a junk car. Now I am getting it again. Do these things only last a year or so or is there another problem?
AUS
Old Apr 2, 2004 | 12:39 PM
Kevlo911's Avatar
Kevlo for President
0705
Diagnostic Trouble Code 0705 points to a problem with the Evaporative Emission Control System.
This malfunction is detected when the EVAP control system has a leak or the EVAP control system does not operate properly. (EVAP = EVAPorative emissions.)
Possible causes include...
- incorrect fuel tank vacuum relief valve
- incorrect fuel filler cap
- fuel filler cap vent remains open or fails to close
- foreign matter caught in fuel filler cap
- a leak in the line between the intake manifold and the
EVAP Canister Vacuum Control Valve
- foreign matter caught in the EVAP CVCV
- leaks in the EVAP canister or fuel tank
- leaks in the EVAP purge line (pipe and rubber tube)
- EVAP purge line rubber tube bent
- blocked or bent rubber tube to EVAP control system pressure sensor
- loose or disconnected rubber tube
- EVAP CVCV and circuit
- EVAP Canister Purge Volume Control Solenoid Valve and circuit
- absolute pressure sensor
- tank fuel temperature sensor
- MAP/BARO switch solenoid valve and circuit
- blocked or bent rubber tube to MAP/BARO switch solenoid valve
- O-ring of EVAP CVCV is missing or damaged
- water separator
- EVAP canister saturated with water
- EVAP control system pressure sensor
- refueling EVAP vapor cut valve
- ORVR system leaks
This is a "jackpot" DTC. It points to so many things you don't know what to check. It is often combined with another DTC which is more specific and therefore more helpful.
Old Apr 5, 2004 | 12:23 PM
meccanoble's Avatar
Sports Button FTW
Originally Posted by kevlo911
0705
- water separator
- ORVR system leaks
i just got this code yesterday. WTF man, too many options to choose from. I had a new fuel pump put in last week, could that be related to it? I have also been driving with very low gas recently, could that be an issue?
Old Apr 5, 2004 | 02:53 PM
glass88jaw's Avatar
i have had this code for the last month and still don't know what the problem is... very annoying
Old Apr 6, 2004 | 06:46 AM
twiggy144's Avatar
IMHO, this 0705 code is a one that justifies paying a Nissan dealer to fix it. There are just too many things to diagnose/check. The dealer should catch the culprit fast.
Old Apr 6, 2004 | 02:05 PM
Kevlo911's Avatar
Kevlo for President
You still are not getting another code besides 0705?
Starrider
Dec 18, 2015 04:43 AM
JoshG
51
Sep 21, 2015 10:41 PM
jchronis2552
Sep 21, 2015 05:52 AM
Steven Orozco
Sep 12, 2015 10:41 PM
dcam0326
Sep 7, 2015 07:26 AM
