Gauge Console backlights?
Old Sep 22, 2000 | 01:38 PM
Superjzf
Hi, Everyone
Need some help..Does anyone know how I can go about changing the light bulbs behind the speedometer and RPM Meter. I want to change the color. I know that its possible but I just don't want to break anything. I got a 96Max and I hope that once I get to the light bulbs I can figure out what kind I need to buy.
Thanx
Old Sep 22, 2000 | 07:07 PM
Whitemax's Avatar
Disco Biscuit
This is a rough set of instructions...
Drop the steering wheel all the way down.remove the two screws at the top of the plastic trim piece in front of the guage pod. with a flat head screwdriver or putty knife(better.Lesschance of scratching anything.) pop off the trim piece. Once off, you will see the pod. remove the one screw at the top, and two at the bottom. Work the pod out, and unplug the wiring harnesses.(there are 3) The bulbs are in the back.
Hope this helps....
Old Sep 22, 2000 | 11:57 PM
Chebosto's Avatar
RIceD OuT moDErAtor
you'll need 5 194 sized wedge bulbs.
Old Sep 23, 2000 | 12:05 PM
seven's Avatar
the 194 wedge bulb's base...
is too big to fit the little bulb holder. i tried myself and they will not fit unless you modify them. anyways, i got some amber bulbs from lighting technologies that are direct fit to have a amber gauge illumination. they're definitely not as amber as the BMW's but they are brighter than stock...look kind of like the mercedes amber lights.
good luck, if you can get the 194's to fit let me know!
Old Sep 23, 2000 | 08:47 PM
kit99bar's Avatar
194 wedge bulb
Cheston have you replaced your stock lights with different 194 bulbs?
Old Sep 24, 2000 | 01:38 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
i changed those with superwhite 194 wedge bulbs. no problems. Dunno why they wouldn fit. Stock ones are 194's. Mine is a 95 Maxima. Unless other years are different. i doubt it tho
Old Sep 24, 2000 | 01:53 AM
CharlieNewbieMax's Avatar
Wat exactly is a wedge bulb? Wat are is proper wattage?
Thx
Old Sep 25, 2000 | 05:03 PM
Superjzf
Thanks to everyone for the info I will try this out and see if I can get those 194 Wedge bulbs to fit. Thanx
Late
Old Sep 25, 2000 | 05:11 PM
Chebosto's Avatar
RIceD OuT moDErAtor
i've got a 97, and they work fine....
i didn't think the bulbs were "blue" enuf so i took em out..
ok wells.
Old Sep 25, 2000 | 05:15 PM
mingo's Avatar
wedge bulbs look like tiny bullets. the end of them are flat and most of time is made of glass instead of metal. the conneting points look like U made of copper
Old Sep 25, 2000 | 06:30 PM
seven's Avatar
I must have bad luck to be the only with
odd sized dash light. well i have a 99 Maxima SE. when i took out the the dash, i tried to put some polarg 194's in there. the base of the bulb just would not fit the tiny bulb holders(believe me i tried). the bulb looked like a miniature 194 and my performance shop didn't carry any in the hyperwhite flavor. so i went to autozone and they happened to have a amber bulb with smaller base, but the top part was just like the 194 bulb.
and yes it is not extremely orange, but they are noticeable and brighter.
i think someone here changed their dash lights green.
Old Oct 25, 2000 | 12:06 PM
JacksMax's Avatar
Have you seen this site?
http://www.geocities.com/amixam69/nissan/dash/
Try this out for your dash bulb replacement. There's lots a pics and looks real straightforward. [I've not done it yet]
Jack
Old Oct 25, 2000 | 12:30 PM
Superjzf
I went through this link to change the guage lights. http://www.geocities.com/amixam69/nissan/dash/ I just followed the pics. The hardest step is taking the black steering column cover off. It has four clips that hold that in place..2 in the middle one on the left, and one on the right. Once I took that off the rest was hell-a-easy.
Late
Miket2006
Mar 1, 2021 03:55 AM
gigabyte
Jan 6, 2017 06:05 PM
RWCreative
Sep 21, 2015 11:01 AM
lrb6805
Sep 17, 2015 04:49 PM
rnb754
Sep 14, 2015 11:39 PM
