Programming Keyless Enty Remote
Old Apr 6, 2004 | 04:40 PM
Dmurry's Avatar
I recently purchased a 1996 Nissan Maxima GLE but it didn't come with the Remote Keyless Entry. I purchased one off of Ebay with the matching numbers and I was told it was very easy to program. Does anybody have a set of directions to perform the programming? Thanks in advance.
Old Apr 6, 2004 | 05:50 PM
DaBombX's Avatar
1. sit inside the driver's seat.
2. close and lock all doors.
3. In TEN seconds, insert and remove the key 6 times. DON'T RUSH. You will see your hazards blink twice.
4. turn the key to ACC position and press a button on your remote. If you see your hazards blink twice again, you're all set. If not, new batteries or something else.
Old Apr 6, 2004 | 06:44 PM
Maxima Mike
Don't you need to hook up a fuse/chip for it to work?
Old Aug 11, 2006 | 07:17 PM
jawwaad05's Avatar
wat if i never see the hazards flash after i put it in 6 times in 10 seconds ??
Old Aug 11, 2006 | 08:12 PM
gx2nds4's Avatar
you have to put it in and out completely so you should try again, it's possible your car didn't come with it but since you have a GLE thats unlikely. Just try to put it in completely and out completely 6 times in 10 seconds if it doesn't flash and you're positive you did everythign right you probably don't have it
Old Aug 11, 2006 | 08:48 PM
jawwaad05's Avatar
i do have it ive been using it for aabout a year now i just dropped my remote and it stopped working so i changed the battery i dont understand why wont the lights flash cuz that doesnt have to with my remote thts just clearing up the old code
Old Aug 11, 2006 | 10:18 PM
99grnmaxgxe's Avatar
It's in the stickies, look for it.
Old Aug 12, 2006 | 12:14 AM
96i30azn's Avatar
please look in sticky called 4th gen how tos
Old Aug 12, 2006 | 12:34 AM
nitink's Avatar
Do as follows
1) With battry removed , press lock key on remote, this will clear id from unit
2) now install battry
3) Follow as described by DaBombX
4) If it still does not work than probably you have reached maximum limit of 4 remotes in ECM, You can take the car to dealer and get ECM reset
5) Or you possibly have bad remote.
Old Aug 12, 2006 | 10:03 PM
nguyen925's Avatar
afterwards you want to try and unlock the doors with your remote. i did this in my GXE and it worked perfectly, down to the automatic windows. (if you press, release and then hold down the unlock button, for about 3-4 seconds, your windows on your drivers and passenger sides will move down slightly enough to have a crack, if you repeat this process the windows will move down even wider.) i did this at 3 AM yesterday and i thought it was the coolest thing in the world, lol.
Old Aug 24, 2006 | 09:34 PM
edlab03's Avatar
bring it back from the dead. atleast i searched! ! !
i recently bought a 96 se which has the keyless entry(tried the key thing, 6 times in and out and the hazards blinked).
i have two spare OEM Infiniti remotes laying around from my I30. The I30 now has an aftermarket alarm so the OEM remotes are no longer needed.
The question here is can I use the Infiniti remotes with the Max? I tried clearing the codes on thee remotes by removing the battery and pressing the lock button as mentioned above. i then put the battery back in and went outside and pressed the unlock button and its still unlocking the Infiniti. Is there a way i can completely reset the codes so it doesnt unlock the Infiniti or do I have to go out and buy actual Nissan remotes?
****forgot to mention that the remotes are from a 2000 I30****
Old Aug 25, 2006 | 11:26 AM
edlab03's Avatar
anyone?
10 char
Old Aug 26, 2006 | 12:51 PM
The_max87's Avatar
LOL mine did the same thing, i went and told everyone!!
Old Aug 26, 2006 | 03:12 PM
Apparition's Avatar
Ichiban King
what a bunch of spoon feeders..
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
maxinout93
Oct 16, 2015 02:53 AM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
Hailstatejig
Sep 2, 2015 06:52 AM
