Ecu !!!!!!
Old Apr 11, 2004 | 08:49 AM
Daniel's Avatar
Ecu !!!!!!
okay i here everyone talken bout an ECU, but what is it and what does it do and what kind of gains would i get ?
Old Apr 11, 2004 | 09:22 AM
THT's Avatar
THT
Throbbing member
The ECU is the "brain" of the car. Reprogramming the ECU with the cracked codes of JWT or Technosquare will result in 15-20hp gains throughout the powerband.
~THT
Old Apr 11, 2004 | 10:10 AM
Radiohead's Avatar
An ECU upgrade remaps your stock fuel program, thus allowing the car to run more efficiently and leaner up in the mid to top end rpms. It'll also raise the rev limiter (JWT ECU) and eliminate the speed limiter in some cases. Like THT said, good for around 10 - 20 HP.
There's a deal going on in the group deal section for a Technosquare ECU right now, good stuff.
Old Apr 11, 2004 | 07:22 PM
Daniel's Avatar
thanks guys but does it work well for an a/t ?
Old Apr 11, 2004 | 07:36 PM
Terran's Avatar
I was wondering about this too. Can it harm the car at all? Like cause a greater chance of knock? Thanks.
Old Apr 11, 2004 | 08:03 PM
Chickan's Avatar
your car still has a knock sensor, so knock should not be an issue, though you MUST run premuim gas, even though you should even without an ECU upgrade. Overall, they really won't hurt your car, they are a tried and true upgrade.
And yes, it will work for automatic or manual, though you must make sure you get an ecu programmed for whichever tranny you have.
I'm waiting for them to raise the rev-limiter on the technosquare ecu (see other thread), then i'll buy one.
Old Apr 11, 2004 | 11:59 PM
BadFish's Avatar
Should someone get an ecu upgrade if they plan on Turbo'ing the max soon? Would this be a waste of money?
Old Apr 12, 2004 | 07:20 AM
I30tMikeD's Avatar
I have never seen a G-force or JWT ECU on a maxima give anywhere near 20hp. I have seen a peak gain of 11hp in the mid range with the JWT ECU.
Old Apr 12, 2004 | 07:29 AM
Taken2DaMax's Avatar
I thought that upgraded ecu gives a "strong" 10-12 hp. Anything above that is comericalism by the manufactors of that certain upgrade.
Still the ecu upgrade is something that you want to have in your arsenal of upgrades. It remaps your air to fuel ratio through out the RPM powerband and JWT upgrade removes the speed limiter. This ecu is a good choice if you plan to go with a MEVI (Middle Easter Varible Intake) later.
Old Apr 12, 2004 | 07:45 AM
C MAX's Avatar
yes it does. i have the jwt and it runs pretty decent with the auto.
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
