power antenna help!
Old Apr 14, 2004 | 09:02 AM
nupemaxima's Avatar
power antenna help!
My power antenna stop working 2 days ago The motor still works but the antenna wont go all the way up. Is this something that can be fixed or do I have to buy another antenna and motor. If it can be fixed someone please post a "how to". thanks and sorry if this has been asked b4 but I dont have time to do a search right now.
Percy
95 se max
Old Apr 14, 2004 | 09:49 AM
HarleyJoel's Avatar
Cleaning the mast off may work. Don't use any lubricants- the mast should be dry and clean of any dirt or grease. You probably will have to replace the mast which is real simple. I bought my new mast at Pep-Boy's and it had the instructions on the package. Like I said it wasn't difficult at all and took about 10 minutes.
Old Apr 14, 2004 | 09:54 AM
Dubbya's Avatar
VK56 Inside
Here is the link. Its pretty easy to do. The only tricky part is feeding the new antenna into the motor. Helps to have 2 people but it can be done by yourself. It took my like 5 or 6 tries to get it right. Just try to remember the way the teeth on the antenna mast cable came out of the motor.
http://www.carstereohelp.org/DoItYou...ssanPwrAnt.htm
Old Apr 14, 2004 | 12:21 PM
nupemaxima's Avatar
thanks guys
Old Apr 14, 2004 | 04:43 PM
Terran's Avatar
Make sure the new and old cord lengths are the same. There's a good chance part of it's broken off in the motor asembly in which case you'll have to take it apart. Even so it's really easy to do. I got one off ebay for $20.
chisam14
Nov 6, 2018 08:56 PM
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
