Help--)white face overlays
Is it important to treat the contact surfaces with Vinyl application fluid before attaching them?
I cannot find this fluid anywhere.
Is there an alternative ?
Any info/pointers will be greatly appreciated.
Deb
Deb
Gauge overlay (reply from import Intelligence)
You can use 1qt of water and 1 drop of liquid dish detergent as an substitute but it will take a bit longer to dry, also make sure you squeegee out all the excess fluid very well.
-Matt
www.ImportIntelligence.com
-Matt
Before you do lay on the water and liquid dish detergent, make sure you clean your current guages with alcohol pads, or if you do not have those, use a lint free cloth and rubbing alcohol. This will clean any excess material that you can not see with the naked eye. Hope this helps.
REDinLV
08-15-2024 12:30 AM
