MEVI Installed!!
on the question of air intake temp, definately cooler is better. to really get cooler air, get the intake out of the engine compartment. the way i did it was by using the info under " Shop Talk--modifications--cold air intake installation". i recommend using 3.25 in. holesaw if your pipe is 3 in. if all of your wheel covers are in place , no water problems unless go thru deep water.
Way to go ImStockBaby. You'd be suprised at how hot intake air is. With my homemade mipipe setup I was still running at 113 degres yesterday(peak). While moving it dropped below 100. It was about 75 outside yesterday. This temp was also with the aid of the 4" hole in my fenderwell. Damn hot.
Originally Posted by BlueC
Ive always wondered, with auto (what I have), will the mevi still make slower times 0-70mph w/o an ecu?? I would thing since the gears are taller, it'll be in the higher rpm range longer than 5spd. Couldnt it also help the times, since there would be less wheelspin with the less torque?
Dave
Im talking about highway speeds. Above 70mph, autos would really have the advantage because of the taller gearing.
I agree. Pretty soon I'm getting this mod on my auto max. Since I already have the JWT ECu with the rev limiter raised the MEVI is just what my car needs.
MaxLife17
Jun 27, 2019 01:37 PM
