squealing noise
Old 04-19-2004, 01:58 PM
puppetmastermg's Avatar
squealing noise
i own a 96 se 5-speed. i was driving today and i suddenly heard a squealing/whistling noise coming from around my front right wheel. I only hear it when i am going forward. The engine does not have to be running. Reverse sounds normal. Does anyone know what this could be? Thanks.
puppetmastermg is offline
Old 04-19-2004, 02:31 PM
Brudaddy's Avatar
Could be the warning clip that they put on brake pads to indicate when you need new ones. I would take them off and check. It is pretty easy...just look in the How-to's.
Brudaddy is offline
Old 04-19-2004, 08:27 PM
I tested it again today and realized it was more of a high pitched groaning. My dad thinks the caliper may have siezed. I don't want to drive it because i am afraid of wrecking something. I will try to remove that warning clip.
Old 04-19-2004, 10:16 PM
will fly for food
Maxima99SE's Avatar
mine has a high pitched groaning sometimes...but mainly when I reverse and lightly press on the brake. i think the caliper has bitten the dust for me
Maxima99SE is offline
Old 04-20-2004, 04:31 AM
BLAZIN's Avatar
hahah i just took mine to the dealer this morning for that....ill let you guyss know how it goes
BLAZIN is offline
Old 04-20-2004, 05:47 AM
Chickan's Avatar
when my car has sat for a bit (2+hours) and it first starts moving (forward or backward) I get a low groan for a second or too, not too worried about it though.
Chickan is offline
Old 04-20-2004, 06:19 AM
suli80's Avatar
i was driving to work today and all of a sudden at about 80mph i heard a high pitch squeel for about 2 seconds, i than exited and stopped at a red light, when i started moving forward again i heard the noise but this time for less than a second.
could this be the same problem? it sounded nasty!
suli80 is offline
Old 04-20-2004, 06:20 AM
suli80's Avatar
bump
forgot to subscribe
suli80 is offline
Old 04-20-2004, 07:39 AM
Brudaddy's Avatar
Actually, that is a common thing that our maxima's do. It kind of sounds like a fog horn? Mine does that too, when I am backing up and lightly press on the brake. It only does it for a sec, and then goes away. It is nothing that I can figure out, and rather than spending money on getting it to go away, I just deal with it. From all I have read here on the .org, it is pretty harmless.
As for the caliper seizing, I don't know. It might have. If it has, you are right...you don't want to be driving. Check it out.
Also, a word of warning....Do not take those warning clips off of the brake pads if you don't check them pretty often(like every oil change/rotate tires). I rotate my tires every time I change my oil(5k miles), so it is no problem for me to just get under there and look. That way, I don't have a lot of surprises. Got me?
Brudaddy is offline
Old 04-20-2004, 01:14 PM
i took it down today and the mechanic said thel ower control arm ball joint and bushing were bad. Nissan doesn't sell the bushing separate so he says i need to replace the entire control arm. He says that is causing the rotor to rub against the caliper
Old 04-20-2004, 03:21 PM
BLAZIN's Avatar
just got back from the dealer and it was the wear sensor on my pads..they said i had nothing left on the pad that it was coming from...got new rotors and hardware also
BLAZIN is offline
Old 04-21-2004, 01:00 PM
i got an estimate and it will cost about $900. I going to do it myself at school. My teacher said it will be easy.
Old 04-23-2004, 11:23 AM
the noise stopped. i still have to replace the lower control arms. thanks to everyone who replied.
Old 04-23-2004, 11:31 AM
will fly for food
Maxima99SE's Avatar
dude that sucks... stealerships are a ripoff.
Old 04-24-2004, 11:17 AM
a_prince1's Avatar
fire your mechanic for saying you can't get bushings seperately.
go to courtesynissan.com/energysuspension
you can get a control arm bushing kit for $30
a_prince1 is offline
hcarter1112
42
07-18-2022 03:35 PM
aw11power
10-10-2021 04:57 AM
D Mason
06-21-2016 04:43 AM
uttadms31
09-30-2015 05:24 AM
Quick Reply: squealing noise
