The brake warning light is always on! What is the problem?
Old Apr 24, 2004 | 10:48 AM
hellochen's Avatar
Hi,
I just got a 95 Maxima but the brake warning light is always on whehter the parking brake is applied or not.
I sent it to STS for a check and got a BIG bill estimate for the change of all the rotors,pads and two rear calipers.
It is overpriced,I think.
So could you please give me some suggestion on how to solve the problem to make the brake warning light working properly?
Thanks and looking forward to your kind help.
Old Apr 24, 2004 | 11:05 AM
WhiteMax96's Avatar
It's probably the switch itself. Remove the front console where is your hand brake,between the two front seats. The switch is there. Look if the little plunger of the switch is working properly, push it down and see if the light goes off. If not, just disconnect the connector, the light must go off. If it goes off, change the switch.
Does STS said that after changing all the rotors and brake pads and the two rear caliper the light will goes off?? If he said that the light will go off after that, then never go back to this place again, they're gonna rip you!!!
Old Apr 24, 2004 | 11:10 AM
a_prince1's Avatar
first things first . . . . check level of brake fluid
hellochen's Avatar
thanks for your suggestion,but I found the brake fluid is below the Min, should I just add some to Maximum?
Old Apr 24, 2004 | 11:12 AM
a_prince1's Avatar
best level just below maximum incase your fluid expands with heat
Old Apr 24, 2004 | 11:14 AM
hellochen's Avatar
But why is the fluid is below the MIN,is there any hiding problem with the brake?
Old Apr 24, 2004 | 11:23 AM
a_prince1's Avatar
keep checking the fluid level for the next couple of days.
If there is a leak somewhere it will decrease.
If not . . . . enjoy the car
Old Apr 24, 2004 | 11:58 AM
crashmanmike's Avatar
As your pads wear down, more fluid is used in the lines to push the thinner pads against the rotors. Thus, the lower fluid level.
Replenish your fluid for now. And plan on replacing your pads soon.
There are two triggers for the light, the fluid level and the parking brake switch. If both of these are okay, then you are probably looking at a grounding problem (highly unlikely).
Mike
Old Apr 24, 2004 | 12:00 PM
hellochen's Avatar
I heard that the piston in the caliper will make the fluid in the resevior increase. Is that the problem?
Old Apr 24, 2004 | 12:02 PM
hellochen's Avatar
How many miles the car runs when I should check and change the pads and rotors?
Old Apr 24, 2004 | 12:15 PM
SzeMan4's Avatar
yea brake fluid ....if your battery light and brake light is on then it is a problem with the charging of the battery...Don't know why but my brake light was on with the battery light and Nissan said it means my altenator is bad
Old Apr 24, 2004 | 01:42 PM
WhiteMax96's Avatar
You should have your brakes inspected at least 2 times in a year. But it depends on how many miles you do in a year.
I was thinking that you checked the level of the fluid before you were posting your question but it seems not.
If the level of the fluid was that low and STS said to you that you need some rotors, pads etc... you really need some.
tsi6001
Oct 3, 2022 10:23 PM
homeyclaus
Sep 3, 2015 06:15 PM
Samedi
Aug 13, 2015 04:05 PM
Gsantos79
Aug 8, 2015 07:41 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
