Need help.........wheels balanced twice..
Old Apr 24, 2004 | 08:52 PM
MaXZilla's Avatar
My brother needs help with his 97 130t. It is a 5 spd and He has about 114k miles on his car and its basically stock until now. He recently got a y pipe installed and 2 weeks later the car shakes at 65 mph to 80 mph (Above 80mph the car dont shake). I checked the cv boot and the rotors and the tires been balanced twiced! I dont know what is wrong with the car! Does anyone know?
Old Apr 25, 2004 | 10:43 PM
2000i30cg's Avatar
You lost a weight off of one of your wheels, that exact thing happened to me, and I took it in for a day, I don't remember what exactly they did, but thats what they told me. Wheels have weights?
Old Apr 25, 2004 | 10:55 PM
inertia777's Avatar
Yes, wheels have weights.
Old Apr 25, 2004 | 10:57 PM
inertia777's Avatar
Same thing happened to me with my 4th Gen Max, I think the problem actually ended up being a broken steel belt in one of the tires.
Old Apr 26, 2004 | 05:50 AM
I30tMikeD's Avatar
If he had the wheels balanced twice then a wheel weight is not missing.
It could be a number of things, but I don't think it has anything to do with the Y-pipe. If the tires are balanced and aligned then I would start looking at the front end parts.
Old Apr 26, 2004 | 06:05 AM
Maximeyez's Avatar
The same thing happened to me. Pull the wheels and rotors and check your calipers. This car is known to blow through calipers. I just replaced mine this saturday and all the shake and noise is gone. When the caliper blows it usually gets stuck in a active area meaning it has preassure on it against the pads and that will cause heavy vibration, noise and fuel consumption. I hope this helps.
Old Apr 26, 2004 | 10:08 AM
rixs's Avatar
I had mine balanced and they still shook also. I finally jacked the car up and discovered that two of them were about 1/16 to a 1/8 inch out of round. So it looks like I'm going to be buying new tires before the next big trip we go on
Matt93SE
May 24, 2019 02:58 PM
dcam0326
Sep 8, 2015 11:02 PM
02nissmax
Sep 5, 2015 01:50 PM
raffivegas
Aug 23, 2015 09:54 PM
