I can not retract the power antenna,what should I do?
Old Apr 26, 2004 | 07:53 AM
hellochen's Avatar
Hi, everybody:
I can not retract the power antenna when I turn off the radio.
Could you please give me some suggestion on this problem?
Thanks.
Old Apr 26, 2004 | 08:33 AM
gansemer's Avatar
You'll need to give some additional information.
Does the antenna motot appear to be operating when you turn off the car? If it is not making any noise, then the antenna motor could be bad or the wiring leading to the antenna. If it is making noise, then the likely culprit would be a broken antenna mast (or more precisely, the plastic piece inside the antenna that the motor drives).
It is also possible that the antenna mast got bent and the kink is causing the antenna to jam as it tries to retract.
Old Apr 26, 2004 | 10:19 AM
psx2dude's Avatar
heres what you DONT do...
go through the automatic car wash
chisam14
Nov 6, 2018 08:56 PM
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
