antenna maintenance
Old May 1, 2004 | 08:26 AM
crappopotamus's Avatar
antenna maintenance
strange, but my antenna needs maintenance... the rubber seal around it is all melty and squishy. is it supposed to be like that, or does it need to be replaced? also, it makes a lot of noise going up and down. i used some wd40, but its still pretty loud. what do you use to grease it?
Old May 1, 2004 | 12:47 PM
comeon... help!
Old May 1, 2004 | 03:23 PM
metal_god98SE's Avatar
hey man, its fine to use wd40....I usually use Starrett M1... basically the same stuff. As long as you keep the telescoping antenna clean and lubricated, it should be of no concern. the antenna is kinda noisy.....i can hear it clearly in the car when i'm parked. Good luck with it
TKHanson
Nov 24, 2018 01:39 AM
chisam14
Nov 6, 2018 08:56 PM
pears
Sep 18, 2015 05:25 AM
DBear
Sep 14, 2015 08:33 PM
Jay556
Sep 12, 2015 05:50 PM
