Exhaust Info/Suggestions
Old May 3, 2004 | 06:57 PM
Maxima Moose's Avatar
I am in the process of purchasing a budget y-pipe. I am also interested in possibly buying a new cat to install at the same time. I was looking at the Random Technology High Flow cat. Any reviews on this combination? Any other suggestions for a cat to go along with the budget Y? Best places to buy the cat would be appreciated also.
Lastly, the how to link on how to install a Random Tech Cat does not seem to be working. Any place else on where to get this info? Will I need new bolts etc?
Thanks in advance,
MM
Old May 3, 2004 | 07:07 PM
I30tMikeD's Avatar
Save your money and keep the stock cat.
Old May 4, 2004 | 03:21 AM
If I had to replace the cat because it was too rusted etc. what would be the best to replace with price taken into consideration?
Thanks!
MM
Old May 4, 2004 | 05:24 AM
I30tMikeD's Avatar
Thanks!
MM
If it really needs to be replaced then I would either go with a car-sound cat or a test pipe. Of course I would not spend the hundreds of $$ on a OEM cat. I have read many, many posts about the Random Tech cat falling apart. But I have only heard a couple bad things about the car-sound cat, and it's much less expensive than the Random Tech. I know warpspeed has the car-sound for pretty cheap.
If you don't have strict smog laws where your at then a test-pipe would be a cheap alternative.
Old May 4, 2004 | 06:27 AM
Brudaddy's Avatar
I think Warpspeed sells the car-sound for like $85 or a little more.
I would recommend to keep the stock cat too. I did this, and it is fine. No need to replace unless rusted out and falling off.
Also, just custom build some exhaust piping. Take your max to a muffler shop and ask them to custom bend you some piping for the b-pipe, and you can just use your stock muffler. They are pretty good as far as the output goes. You should be able to do this for like $50 or so. I did.
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
TheMafia
Sep 4, 2015 08:26 AM
