Sea Foam
how do we go about adding the sea foam directly to the injectors? i see on the can it says it is possible to clean injectors but im clueless how to do it.
i just added seafoam to the gastank and to the crank case. i felt some good results and i can actuallly feel a diference. all tat STP and other brands just felt like nothing, with seafoam i can actually feel a difference. P.S. is it ok to just pour this down the TB it says so on the can but sounds a lil strange, unless there is a spray also.
brake booster is very easy to find, its the only vacuum line going to the brake booster. look at your brake fluid resevoir and look straight back towards the driver seat. Voila! that big black thing is your brake booster.
![](https://maxima.org/forums/images/smilies/support.gif)
the vacuum hose is easy to find: pull the hoses off while the car is running and the one that is sucking in air is the vacuum hose.
Anyways if you don't want to do that, the vacuum hose is located behind the throttle body. The hose that connects from the midpipe to the intake maifold behind the throttle body. If you still can't find it, it's the hose on the left of the brake fluid reservoir.
Originally Posted by kelvin927
but it's hard to find a place to buy Sea Foam product.....any one know where they sold in NYC....cause I want to try it...
they have it in jersey, advance auto has it, and so does napa and autozone, got it today, funny thing is i put 4 oz into a half a tank of gas, but i got no pufy smoke from my exhaust
but i try to find some stores at NYC....cause i don't want to drive all the way to NJ for the fuel injector cleaner..........
use the phone............................................. ..........................................
97_GXE
09-15-2015 06:47 AM
SB97MAX
06-15-2001 01:13 PM
