ECU code 0302
Old May 6, 2004 | 01:06 PM
soshiv's Avatar
ECU code 0302
I have been getting a lot of engine ping from my car and i checked my ECU for codes and it gave me code 0302....i checked it out and it gives me "EGR System Hi/Low Flow"...what does this mean? and what could be wrong?
Old May 6, 2004 | 01:12 PM
Kevlo911's Avatar
Kevlo for President
0302
Diagnostic Trouble code 0302 points to a problem with the Exhaust Gas Recirculation system. The malfunction is detected by the Engine Control Module when no EGR flow is detected under conditions which call for EGR. Possible causes include:
- The electrical harness or connectors (valve circuit open or shorted)
- The EGR valve is stuck closed
- Weak or dead battery
- The EGR passage is clogged
- Faulty EGR temperature sensor circuit
- A leak somewhere in the exhaust system
The EGR Volume Control Valve may be tested with an ohmmeter. Disconnect the electrical connector. Looking at the connector half which is attached to the EGRVCV with the latch at the 12 o'clock position you will see two rows of three terminals. The top row is numbered 1-3, right to left. The bottom row is numbered 4-6, right to left. Measure the resistance between these terminal pairs:
2 1
2 3
5 4
5 6
... all resistance values should be 20.9-23.1 ohms at 68 degrees F.
Reconnect the EGRVCV connector halves. Turn the ignition switch ON OFF repeatedly. Verify that the EGRVCV shaft moves smoothly forward backward according to the ignition switch position.
The Exhaust Gas Temperature Sensor may be tested with an ohmmeter. The specifications are ...
- at 32 degrees F, 0.68-1.11 Megohms
- at 122 degrees F, 0.09-0.12 Megohms
- at 212 degrees F, 0.017-0.024 Megohms
Old May 7, 2004 | 03:25 AM
soshiv's Avatar
is this causing my engine to ping?
Old May 7, 2004 | 04:03 AM
knight71's Avatar
I had the same thing 2 weeks ago...I decided to get BG44k fuel injection service done to my car through a local mechanic,,,Code went away..Car runs really well now..Here is a link to their website:
http://www.bgprod.com/
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
