why e-brake light on?
Old May 7, 2004 | 11:29 AM
spreenyk888's Avatar
yeah the e-brake light on the dash goes on for awhile, then shuts off for awhile, then goes back on. and before anyone asks NO the e-brake is not pulled. the brake fluid is also fine. anyone know?
Old May 7, 2004 | 11:31 AM
Keith P's Avatar
Check the brake fluid level in the resevior.
Old May 7, 2004 | 11:41 AM
Ladzio's Avatar
just what he said
Old May 7, 2004 | 03:56 PM
cool but im not too mechanically inclined, so how does one go about doing this?
Old May 7, 2004 | 04:01 PM
happyricefob's Avatar
V^___^V
ugh...pop your hood and locate the brake fluid container. if your brake fluid is lower than "min", then u'll need to fill it up. you can go to stealership and buy 1 bottle of DOT brake fluid for $5 or so. go home, fill it up, and the light should go away.
if not, the you're brake lines probably have air in it. u'll need to bleed it and compress out the air. and here's how u bleed ur brakes if necessary >> http://www.greghome.com/Greg's%20Gar...edBleeders.htm
V^___^V
btw ur owner manual has a section regarding brake fluid level. u can check that out for additional reference....
Old May 7, 2004 | 04:07 PM
ah well no one read my original post where i stated "brake fluid is fine" i checked that out under the hood. oh and yeah i dont have an owners manual, i really wish i did.
Old May 7, 2004 | 04:42 PM
Ladzio's Avatar
sorry, must hav been half-blind, bleed the system, costs $0 and might solve the problem. Look into Maxima How-to for directions
Old May 8, 2004 | 08:20 AM
chris j vurnis's Avatar
Make sure the connections for the lines going into the calipers are tight. If they have gotten loose, they could be slowly leaking fluid.
And then they might completely start gushing from the connections if you happen to hit the brakes hard. You'll know if you have that problem when your brake pedal goes all the way to the floor with almost no effort.
Old May 9, 2004 | 08:59 PM
Keith P's Avatar
Does your battery charge light ever come on? Check fuse #13 in the box by the battery. If this is ok, you may have other electrical (not brake) problems in the charging system. Check the usual stuff there.
Old May 9, 2004 | 09:35 PM
THT's Avatar
THT
Throbbing member
When this happened to me, it turned out my entire rear brake assembly needed to be replaced. The shop said it was a rare occurence but something to consider, just in case.
~THT
Old May 10, 2004 | 07:06 PM
Keith P's Avatar
Here is another link
http://forums.maxima.org/showthread....5&goto=newpost
Old May 10, 2004 | 08:39 PM
thank you everyone for the help. as far as the battery charge light going on, well its not. i already had that problem when both the emergency brake light and the battery light went on at the same time, and yes, it was the alternator, so i know thats not it.
the rear brake assembly was already completely replaced about 10k miles ago, probably less. new pads, rotors, and calipars were installed on the rear brakes. new pads and rotors in the front.
in the last day or so ive noticed a grind coming from my front brakes again. could it be new pads already? im gonna have a friend check it out real soon, but the brake fluid level is still fine, so i dont know about a slow leak.
thanks everyone for the help, im going to bed now even tho there are severe lightning storms hittin hard rite now!
DJLAX152
May 4, 2021 11:46 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
