what to use for eyebrow installation?
Old May 8, 2004 | 12:25 PM
MAXecutive's Avatar
I was wondering what kind of glue should be used to install the eyebrows. What will I do If I need to change a light? What did you guys use?
Old May 10, 2004 | 05:38 PM
MAXecutive's Avatar
Can anyone help me, I just need to know what to use to glue them down.
Old May 10, 2004 | 05:52 PM
Doc's Avatar
Doc
Double sided 3M tape should do the trick.
Old May 10, 2004 | 05:56 PM
MAXecutive's Avatar
I would like them as flush as possible, so wouldn't the tape make them stick out. What kind of tape, the same ones that are on the ventshades? If I glue, would it be possible to remove them? If I tape, wouldn't it be stolen easily, I live in the Bronx, where HIDs are stolen every 2 mins. lol.
Old May 10, 2004 | 06:13 PM
Doc's Avatar
Doc
You should be able to buy some real thin 3M tape somewhere. I think with glue you may not be able to get them off without having a lot of headaches. As for the tape, the eyebrows would be very hard to get off without destroying them, which would probably deter theft. The tape is like the stuff used on Ventshade, but you may even find a thinner roll. I believe with the tape the lids will sit quite flush. I'm planning on adding a set myself sometime.
Old May 10, 2004 | 06:17 PM
MAXecutive's Avatar
but the only double sided tape I've seen that is weather proof is the 3M that is the same size on the ventshades, I know theres regulare 3M thin double sided tape but not for outdoors.
I heard someone say use some kind of epoxy before. What do you think, and where would I find that from?
Old May 10, 2004 | 06:22 PM
Doc's Avatar
Doc
Hmmmm....not sure I can help. I'd check with a local body shop or something like that. They should be able to steer you in the right direction. I know the weatherproof tape you speak of isn't too thick because Ventshades sit very tight to the cars they are installed on. I'm sure some of the guys here could help with the epoxy idea if they check out your thread. GL with however you decide.
Old May 10, 2004 | 06:24 PM
MAXecutive's Avatar
okay thanks for your help
MAXecutive
Old May 10, 2004 | 06:26 PM
Doc's Avatar
Doc
MAXecutive
Your welcome. I only wish I could have helped more.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
