**95 to 97 conversion Foglamps**
Old May 8, 2004 | 12:40 PM
joeynym's Avatar
Back in the Max
i am converting my 95 maxima front end to 97 max, i just ordered factory fog lamps with brackets, i already bought the bumper , but i noticed it had a piece of plastic going thru the hole where the fog lamp goes..... do i just remove the strip of plastic???? where does the bracket mount to, is there suppose to be holes in the bumper or do they make an aftermarket bumper for 97 maxima with fog lights???
has anyone did this part of the conversion before
Old May 8, 2004 | 12:42 PM
gtr_rider's Avatar
192.168.1.1
There is a seperate bumper for the 97 with fog lights as that same idea goes for the 95 bumpers. You purchased the 97 w/o fog light bumper.
Old May 8, 2004 | 12:47 PM
Kevlo911's Avatar
Kevlo for President
Just cut het little plastic black bar.
Old May 8, 2004 | 12:49 PM
joeynym's Avatar
Back in the Max
i dont think they had a choice, with 95 bumper they had a choice, but with 97 i think u can just break off the strip of plastic, but there is no screw holes for the fog lites
Old May 8, 2004 | 12:52 PM
Kevlo911's Avatar
Kevlo for President
The screw holes for hte 97-99 are in the metal part of the bumper. They are not in teh bumper cover.
Old May 8, 2004 | 12:53 PM
joeynym's Avatar
Back in the Max
i dont have the 97 bumper , is that going to be a problem, or does 95 bumper have the holes????
Old May 8, 2004 | 12:55 PM
Kevlo911's Avatar
Kevlo for President
I have no clue, go try to put hte brackets on and see if it works. I believe it will
Old May 8, 2004 | 01:17 PM
joeynym's Avatar
Back in the Max
thanx alot kevlo911, (i just bought the foglites on ebay, i should have them this week, just trying to get a jump start)
if anyone has done this conversion , please help with any suggestions
Old May 8, 2004 | 01:25 PM
Kevlo911's Avatar
Kevlo for President
http://forums.maxima.org/showthread.php?threadid=46513
Old May 8, 2004 | 02:36 PM
Conrad283's Avatar
I need a truck
Once you take the bumper off you'll see that there are 3 holes in the bumper support frame, I dunno what to call it, this is where the bracket will attach to. The hole pattern on the bracket on the 97-99 should be the same as the 95-96, as many people have done this conversion
Old May 8, 2004 | 07:26 PM
joeynym's Avatar
Back in the Max
thanks Conrad283
Old May 9, 2004 | 12:10 AM
nismo_SHA's Avatar
how are you going to switch the fog lights on and off? i have amax96 gxe and theres no switch for foglights...as far as i know..i have def. thought about getting fog lights though mine as well upgrade to either 97 bumper primed with fog light holes or else just get a "m" bumper like me :P
Old May 9, 2004 | 04:38 AM
Conrad283's Avatar
I need a truck
Originally Posted by joeynym
thanks Conrad283
No problem
Old May 9, 2004 | 04:56 AM
joeynym's Avatar
Back in the Max
nismo_SHA i am not worried about the wiring, i will wire them right into the parking light with a relay, they will go on whenever i turn the parking lights on......
Old May 9, 2004 | 01:53 PM
nismo_SHA's Avatar
good idea can you post how the operation went? im going to have to do that too.. and how much dough
Old May 9, 2004 | 08:19 PM
joeynym's Avatar
Back in the Max
i will def hook u up on the info, the wiring part is the easy part for me, i will tap into the small side marker the light in the bumper cover, or maybe the cornering lite, then hook that wire up to a relay so that when the parking lites go on, the fog lites will tooo, they wont have an indepent switch.........
KabirUTA13
19
Oct 17, 2015 02:15 AM
Calabar
Oct 5, 2015 09:57 PM
kjlouis
Sep 14, 2015 11:22 AM
Hdnseek
Sep 9, 2015 05:55 AM
