how aobut cv joins replacement?
I wil be replaceing mine ,maybe today.It's easier to just replace the whole half shaft.It's also cheaper then just buying the cv joint by itself.The half shaft is about $70 with core exchange.It comes with both inner and outer cv joints.You need to remove two bolts connecting the strut and the spindle and remove the tie rod and sway bar end link.You should be able to pull out the half shaft out.It's not that hard of a job.
are there any performance type drive axles for us. im not looking for something to increase power but i want something that is strong and built to last. i purchased a set of axles 3 years ago and they are already clicking and the boots are perfect. worst part is the warranty was only for a year so i need a new set. any good performance axles and how muc are they, i believe raxles.com has some. does anybody have them or know abouth them...?
A good breaker bar to go with that 36mm socket as well.
Don't get the fork/wedge shaped separator unless you want to tear the boot. I use a 2-jaw puller, while others don't even disconnect the tie-rods.
if you cv joint has been leaking for a while..and its dry in there.i would have the whole axcel replaced with a rebuilt one.. cost of the rebuilt axcel is liek 115 bucks.. u shold be able to take it off and put it in yourself if you mildy mechanically inclined
The Frye
09-02-2021 11:03 AM
dvcamp
09-18-2015 10:17 AM
Maxima30
09-07-2015 06:13 PM
