European corner lights
Sep 23, 2000 | 08:35 PM
Can anyone explain to me how to install european corner lights, the ones that are just between the front door and the front fender. What does the wiring involve. What type of wiring should I buy if any? Also, what do I use to make a hole in the metal?
'99 Maxima ES Limited: clear corners,custom red/clear tails,5" muffler tip,wood dash,red calipers,hood deflector,all xenon blue lights. Future Mods: FSTB,touring wing,upgraded sound system,GTR emblems.
My website: http://www.geocities.com/natanis_ca/index.html
Sep 25, 2000 | 04:40 AM
They are called side turn signal repeaters >>
You're going to have to cut holes in your fenders. The size and shape of the holes will be dependent on the type of repeater you buy...some require a circular cutout others a rectangular cutout. Cutting the hole is not actually that hard. You'll need a Dremel or some other kind of rotory tool with a few medium to fine cutting wheels. If you've never used any of these tools before, it'll be a good idea to practice on a piece of scrap sheetmetal first.
As for the wiring, you'll need to splice the hot lead of the repeater to the hot lead of the turn signal in your bumper and ground to somewhere that is acceptable on the chassis.
