Bulbs for Step Light and Map Light?
In a 1999 Max, the step (door/courtesy) light is a 2.7-watt wedge bulb (161). Can I put a 5W PIAA wedge bulb in these without problems?
The map light (AKA "front personal light") is a really weird 10-watt bulb. The manual does not give a bulb number for it. Has anyone replaced it sucessfully? I want to put a really bright bulb there to match a PIAA Xtreme White dome light, and I need to know what type goes there.
That 1895 bulb, although it will fit, will suck (not anywhere near bright enough. I found that a bulb made by Raybrig in Japan worked great. The key is that it should be at least 8 watts... Check this out:
http://www.xtremewhite.com/ORD-Light...83-1-1-1-1.cfm
The Frye
Sep 2, 2021 11:03 AM
Maxima30
Sep 7, 2015 06:13 PM
trungg86
Sep 4, 2015 04:58 AM
