Engine misfire??
Old May 13, 2004 | 06:38 AM
Maxine's Avatar
Engine misfire??
I was driving to school this morning,(little late) so i was passing people. And i was going 70 mph and gave it half throttle to pass somebody and the rpms jumped to 4000 and sounded like it bogged down went up a little and bogged down again, so i got off and did it and no bogging this time. Any ideas on what it could be??
thanks
Old May 13, 2004 | 06:59 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
check your fuel injectors
Old May 13, 2004 | 07:03 AM
Maxine's Avatar
That sucks i was hoping for a simple problem. Injectors are expensive.
Old May 13, 2004 | 07:05 AM
killcrap's Avatar
www.jerryromenissan.com parts are inexpensive there
Old May 13, 2004 | 07:50 AM
Maxine's Avatar
should i replace the one if it is the problem or all six??
Old May 15, 2004 | 04:06 PM
Kevlo911's Avatar
Kevlo for President
0603 0604 0605 0606 0607 0608
If one cylinder is misfiring the problem is spark or fuel. A misfire due to a spark problem usually results in a Service Engine Soon light and one of these Diagnostic Trouble Codes:
0608 - Cylinder 1 misfire
0607 - Cylinder 2 misfire
0606 - Cylinder 3 misfire
0605 - Cylinder 4 misfire
0604 - Cylinder 5 misfire
0603 - Cylinder 6 misfire
There are two tests the home mechanic can make, the sound test and the resistance test.
Sound test...
This test is performed with the engine idling. Use a mechanic's
stethoscope or a length of rubber vacuum hose, and listen to each injector.
All injectors should sound alike. If you find one which makes a different
sound (or no sound at all) you have found a problem.
Resistance test...
This test is performed with the engine off. Use an ohmmeter to measure the
resistance of each injector. This does not require removing the injectors.
I don't know the correct resistance value for the injectors on your model,
but they are typically a low number such as 16 ohms. The important thing
is they should all be equal. If you find one injector with substantially
higher resistance than the others, it is bad. If you find one with zero
ohms (short circuit) that is truly unfortunate, because the injector is bad
and it may also have damaged the Engine Control Module (the computer)
because of excessive current drain.
Measuring the resistance of the front bank of cylinders is easy because the
injectors are in plain view. Disconnect the injector electrical connector
for cylinder #2, measure the resistance, reconnect the connector. Repeat
for the cylinders #4 and #6.
Measuring the resistance of the rear bank of cylinders is almost as easy,
but it is difficult to reach the injectors. The resistance may be measured
at a conveniently located electrical connector. Notice the largest,
thickest electrical harness at the top of the engine. This is the Engine
Control Harness and it is shaped like a U, with the open top of the U at the
driver's side of the car. The U has two corners. Look at the corner
nearest the passenger seat. Just inside that corner you will find an 8-pin
electrical connector. This is connector F131. Disconnect this
connector. Now look at the male part, the connector half with the pins
exposed. They are arranged in two rows of four pins.
The pins are numbered 1 - 4 (top row) and 5 - 8 (bottom row).
Measure the resistance of:
- injector #1 between pins 1 and 2.
- injector #3 between pins 1 and 6.
- injector #5 between pins 1 and 5.
Be sure to measure the PINS, not the female receptacles.
The dealer's shop is equipped with high-tech diagnostic instruments. These are wonderful devices but they are expensive and the dealer has to recover his cost by charging you for diagnostic time. Sometimes the home mechanic can do legitimate diagnostic work with nothing more than a ohmmeter and a rubber tube.
To Test Ignition Coils:
With the ignition off, disconnect the electrical connector from the ignition coil. Connect the positive (+) probe of an ohmmeter to terminal no. 1 and the negative (-) probe to terminal no. 2 of the coil connector - the meter should indicate infinite resistance. Reverse the meter leads ( negative probe to terminal no. 1 and positive probe to terminal no.2) - the continuity should be indicated, but not zero ohms. If the results are not as specified, replace the coil.
Connect an ohmmeter between the secondary terminal ( the one that the spark plug connects to) and terminal no. 1 - the meter should indicate infinite resistance. If not, replace the coil.
Note - Ohm meter to test coils is not the most reliable way. Some peoples’ coils tested perfectly, but they still misfired.
Old May 18, 2004 | 10:48 AM
luga982's Avatar
hey man,
i had that problem a while back, and it was aggravating.it is definitely your coils, and they need to be changed as soon as possible.it is a piece of cake, and it takes about 15 minutes to change them.
to change the front three, you need an allen key, and for the rear three, you need a ratchet.
make sure that you change all of them, and the problem go.
it is cheaper to do it yourself though.
Old May 18, 2004 | 12:24 PM
Nick7455's Avatar
Yup...same tihng happened to me a month or 2 back....it is your coil -_-
Old May 18, 2004 | 12:25 PM
Nick7455's Avatar
If you are looking to save money then just check your engine code and just change the one coil that is messed up....thats what I did and my car runs great now
Old May 18, 2004 | 12:50 PM
Nismotic's Avatar
Always sunny in philly
It happened once to me after i changed my spark plugs, but then it went away?
shilov
Feb 19, 2024 09:40 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
