people with KYB strut mounts... need your opinion....
Old May 14, 2004 | 01:08 PM
happyricefob's Avatar
V^___^V
so my rear tokico HP shocks blew out. i picked up some rear kyb agx + kyb strut mounts.
okie basically this is not really a big issue, i'm just curious why maxmod says kyb strut mounts aren't good replacement. i need some personal opinion on that.
Old May 14, 2004 | 01:31 PM
V^___^V
bump...no one can help me?
Old May 14, 2004 | 02:29 PM
drewm's Avatar
I never knew KYB made rear strut mounts, only front ones. I hear the front ones basically act like broken stock ones, from every single person who owned them.
Then again, why get new rear ones? they shouldn't wear out, they are just a big hunk of metal with a little rubber ring. You sure you aren't referring to the KYB dust boots?
Old May 14, 2004 | 02:32 PM
Kevlo911's Avatar
Kevlo for President
Ya, no need to change the rear OEM mount unless you replace it with a Motivational Mount style mount(1in more travel space).
Old May 14, 2004 | 05:15 PM
UTIMaxima's Avatar
I've had no problems with mine. Just use a small amount of grease so they don't make noise. But you probably are fine staying with the oem ones.
Old May 14, 2004 | 05:40 PM
maximus_pr's Avatar
some people have issues with noise in front using kyb mounts only thing i may think is rubber in mount being softer than oems as for rears if you buy the kyb rear mounts you only get the bushings that goes on shaft of strut thats the only thing that wears out
another thing unless your front mounts are very very bad like rubber broken or anything like that just buy the oem strut bearing
Old May 14, 2004 | 05:59 PM
VQuick's Avatar
Chassis Freak
Tangential question:
The Motivational mounts seem like a must for anyone who's lowering. 1" more travel, great. But does that mean the entire car can dip 1" lower? Would that mean you're more likely to scrape going over a big bump?
Old May 14, 2004 | 06:33 PM
maximus_pr's Avatar
no the Motivational mounts dont drop your car 1" more it gives you 1" more travel thats means your shock wont bottom out or bottom out less
Old May 14, 2004 | 06:46 PM
VQuick's Avatar
Chassis Freak
I know it doesn't drop it 1", my question is, is the additional inch of travel at the bottom, meaning the car can go 1" lower even though it sits at the same height?
Old May 14, 2004 | 07:05 PM
maximus_pr's Avatar
yeap !!!!!
Old May 14, 2004 | 10:15 PM
Oblongshapes's Avatar
Is that the noise i got with my KYB AGX's i just installed, like little birdies singing their hearts out in the rear of your car?
Grease them eh? Does this mean i have to take the strut off again after i just got aligned :*(...
firestone will hate the day they gave me a lifetime alignment..
on a side note... i bought Eibach camber bolts when i redid my suspension, and the camber rating is the same before the alignment as it was after. I told them they were on there, but they didnt touch them. The left read -1.6 and the right -.02. Im going to go make them fix it !
MaxLvr21
Oct 17, 2015 12:11 PM
maxima-junky
Oct 7, 2015 06:13 PM
BobTX10
Oct 7, 2015 08:43 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
