msd ignition
Old May 20, 2004 | 05:10 AM
maximadoc's Avatar
msd ignition
dear maxima gods,
i tryin to put to put a msd ignition into my 96 max, gxe. do any of you know where to look? and what model num. msd i should get? thanks
-maximadoc
Old May 20, 2004 | 09:57 AM
maximadoc's Avatar
does anybody know anything about msd ignitions? my friend said that they extend your spark for better performance.
HELP!! any info is welcome
Old May 20, 2004 | 10:45 AM
Ceasars Chariot's Avatar
Old Maxima Legend
i have checked on the msd, msd told me the stacker 8 would work, then i call back to find them telling me nothing would work on our cars. i called several others vendors and they told me the same thing so i ended the search. as for as i know the msd ignitions wont work
Old May 20, 2004 | 12:19 PM
nismology's Avatar
Our stock ignition systems are more than sufficient. There are ppl running over 400 WHP with no spark problems.
Old May 20, 2004 | 12:59 PM
maximadoc's Avatar
alright, thanks fellows. ill think of somethin else to put on my Max. -later
Old May 20, 2004 | 03:53 PM
Magikone69's Avatar
well if we can run over 400 hp on stock ignition system does that mean upgrading the ignition will not give us any better performance? i was always curious when ever someone says our stock ignition is good enough. i mean the stock y pipe is good enough to help give the max 190hp but with an upgraded y pipe we can get so much more.
Old May 20, 2004 | 08:44 PM
nismology's Avatar
You're looking at it the wrong way. An ignition system is not a power "adder" per se. You buy an upgraded ignition out of necessity, not because you want your car to be faster. Cause if that's what you're after, you'll be sorely disappointed. You buy a y-pipe to be faster. That's like saying you're installing a high-pressure Walbro fuel pump to add HP. It's completely unnecessary unless you're boosted, much like an upgraded ignition and even then, it would take extreme power levels to overcome the stock ignition.
You're logic is pretzeled bruh...
Old May 20, 2004 | 09:09 PM
Magikone69's Avatar
well thanx for clearing that up bruh... your explanation is the 1st ive seen that makes sense. i understand what you are saying with the fuel pump and i see what you mean since an upgraded fuel pump isnt really an HP add on, i guess the same could be said for ignition
Old May 20, 2004 | 09:13 PM
Vyrus's Avatar
I believe the HKS Twin Power ignition unit can be used on out car. To my knowledge it is the only system compatable with our DIS. The only person I know who has it is 1Max2NV, I have not read anything on it but I have seen a picture of it in his engine bay.
-Cyrus
Old May 21, 2004 | 01:37 AM
maximus_pr's Avatar
here is jorge lazcano's 7+sec 96 300zx engine using the MSD DISC-4 AMPLIFIER with 3 ELECTROMOTIVE coils
Old May 21, 2004 | 01:41 AM
maximus_pr's Avatar
the beast
1130hp with a 3.0 vq engine(no quite 3.0 anymore)
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Aug 8, 2020 10:31 AM
Gingerheadman
Oct 1, 2015 05:11 PM
msellas
Sep 23, 2015 09:16 PM
rnb754
Sep 14, 2015 11:39 PM
