Help? My doorlocks gone crazy
the doorlock on my Max are buggin out.. They keep locking on there own even with the car turned on. I was wondering if it could be a problem with the factory alarm or the doorlock switch. I tried unplugging my battery terminals to reset the computer but that didnt help. Any input will be appreciated. Thanx...
And72299@aol.com.
And72299@aol.com.
yo i think theres a problem with mine too but its alway sbeen that way, when i go to open my door with the key i have to turn to lock first all the way then unlock and it will unlock but after i open the door it locks itself and if i open it from the inside the horn starts beeping idk so i just cruise with wierd *** doors, also i have no remote for keyless i was gonna pick one up from ebay though and see if that would work to straighten things out cause its real annoying not having a key fob im used to having them to get in
I have had the same problem for a while, but I already asked on the *.org and got an answer:
When you unlock your doors, one of the door lock levers inside does not unlock all the way, probably because of dirt or something. That cause all other doors to lock instantaneously. In my case it was the passenger door. I was too lazy to take the door handle/lock assembly appart and clean it, so what I do every few weeks is just grab the lock lever and do this about 15-20 times: lock/unlock/lock/unlock/lock.... you get the idea. Ghetto, but it takes about 10 seconds every few weeks.
Hmm, my doors lock automatically but that's because of my alarm
Umm, You know when you try and unlock the doors from the inside using the door unlock (not physically reaching over at unlocking it), they can't because it gets stuck. There could be a rod out of place. Either that, or the fuse is bad, or there's a short somewhere
ivorton23
09-28-2015 09:08 PM
ColdCananda
09-20-2015 10:45 PM
Maxima30
09-07-2015 06:13 PM
