Any suggestion is appreciated
Code 0215 is P1446 "EVAP canister vent control valve closed", could that be my problem in my car not starting right. My RPMs act very weird. They jump up and down really fast after barelly pushing on the gas or just letting of the gas pedal. A couple of times I've seen them delaying a little bit, when I push gas, the needle won't move for a couple of seconds. I have an automatic if it helps. Another code that i have is 0304, which is a knocking sensor. I've read that its not what causing my problem.
Search didn't help me out at all.
What that code actually means? WHat should I do? I'm running out of ideas.
I ran the car today again, and now I have another code. Its 0704, which is a problem with the Evaporative Emission Control System Pressure Sensor. Could this codes be from one problem? I don't even know what to fix now, but changing every part in the car.
Common people, help me out here. I've got no money for a mechanic to just pay hundreds of dollars to see whats wrong with my car. Share your experiences...I'm sure that a couple of people here had to deal with the same or maybe similar problem. That's the whole point of the forum to share knowledge and help each other.
REDinLV
10-18-2015 05:31 AM
DC_Juggernaut
09-28-2015 04:07 PM
