does the ecu contol the idle
Old May 26, 2004 | 07:30 AM
sagemistse's Avatar
On Sunday I did a self diagnostic and got back error codes that informed me that i needed a front heated o2 sensor, and a knock sensor. After the check the service engine soon light no longer was on. Yesterday I noticed that my car was idling alot higher than normal. It usually idles at the first mark beneath the 1000 rpms mark no it is right below 1. Any ideas of what could have caused this???
Old May 26, 2004 | 07:53 AM
Prophecy1's Avatar
Yes in this situation. You did not return the screw back to its right spot.
Proph
Old May 26, 2004 | 07:56 AM
sagemistse's Avatar
I kinda thought that was what it might be what is the correct spot?
Old May 26, 2004 | 08:51 AM
Chickan's Avatar
I believe the correct spot is in the center, though you might want to check me on this.
Old May 26, 2004 | 09:17 AM
TooMAX's Avatar
Check... the FAQ
http://vbxmaxima.8m.com/ecu.html
Old May 26, 2004 | 09:19 AM
DAVE Sz's Avatar
Hooooooonda.....
The IACV controls idle and from what I read the IACV isn't connected to the ECU in any way. Why are you worried about a 100rpm increase during cold idle?
Old May 26, 2004 | 09:50 AM
sagemistse's Avatar
Its more like 400 rpms the cold idle is now what it was when I had the AC on. Now when the AC is on it Idels over 1
Old May 27, 2004 | 09:52 AM
sagemistse's Avatar
I put the screw back in the correct place and it worked my idle is back to normal.. thanks for the help!!!
Old May 27, 2004 | 10:16 AM
DAVE Sz's Avatar
Hooooooonda.....
CORRECTION!!!
The ECU does apparently control idle as well. Good day.
gigabyte
Jan 6, 2017 06:05 PM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
