have some lowering questions, and Anyone use energy suspension bushings?
Old May 31, 2004 | 06:53 PM
ManualMaxima's Avatar
5th Gen till she dies!
i am putting on springs and struts tomarrow and i am going ot put new rear bushings on. has anyone use energy suspenion bushings? are they good compared to stock?
also i am going with sprints what is your experiance with camber adjustments, will i need it you think?
Old May 31, 2004 | 07:02 PM
d_warner's Avatar
Old Timer
You will definately notice more bumps etc in the road, but suspension performance will be awesome. You do know that you have to burn the old bushings out right? And cut the race with a hack saw. It's not real hard, just time consuming.
Old Jun 1, 2004 | 10:00 PM
volkl77's Avatar
I've used Energy bushings for the front control arm, end link and sway bar mounts. Everything was drop in except the front control arm bushing. I don't know if it was typical but it took a 12 ton press and an air hammer to get the old ones out. Love the ride improvement though, much firmer and more responsive.
I was unaware that rear bushings were available. I'd been led to believe that you'd have to replace the whole beam and link assembly. Do you have the part #s for the trailing arm and link bushings???
Cheers!
Old Jun 2, 2004 | 09:05 AM
ny96max's Avatar
with Sprints you WILL need Eibach camber bolts to get the car into the correct alignment. Let the suspension settle in for a week or two before you get it re-aligned.
Ant
The Frye
Sep 2, 2021 11:03 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
