Cold Start Squeal
Old Jun 7, 2004 | 06:47 AM
Corey_25's Avatar
Cold Start Squeal
Every morning it squeals for about the first fifteen minutes then stops
I'm thinking belts or belt tensioner
I sprayed some belt dressing on it, stops it for a few seconds and changes the pitch of squeal
Is their a way to tension the belts?
Anyone have any experience with this, DIY or not
its a 98 with 154 KM
Old Jun 7, 2004 | 08:15 AM
Midknight MAXX's Avatar
You either need new belts or you need adjust the tension.
Old Jun 7, 2004 | 09:14 AM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
Check your belts, if they are in good shape, they're probably loose and need to be tightened, use the belt tensioner adjuster, but don't overtighten .. if your belts look bad then it's time for them to be replaced
also pls. stop using belt dressing on your belts, this will cause your belts to fall off sooner or later
Old Jun 7, 2004 | 10:42 AM
Corey_25's Avatar
Thanks for the replys
I'll inspect the belts tonight
Anybody have a diagram or link for adjusting the tensioner?
gustavison
Oct 4, 2015 06:50 PM
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
tardrex
Sep 11, 2015 07:35 PM
trungg86
Sep 4, 2015 04:58 AM
