Rack and pinion? Should I replace it?
Old Jun 8, 2004 | 01:23 PM
badboymel's Avatar
Hello everyone.. I got a question for all you Master Mechs out there. I'v had both my steering boots torn for who knows how long, but when I drive below 60 no problems and when I drive faster than that I get alot of front end shake....
I know its not the allignment or balance just had them done. Is it the ball joints, or maybe a tie rod. If it is the rack and pinion how much is it going to cost and can I do it myself
Old Jun 8, 2004 | 01:58 PM
NmexMAX's Avatar
dot dot dot ...
Mine have been ripped for a long time too, though my car doesnt shake. Maybe check if there is play in any of the front wheels, which maybe wheel bearings or ball joints. Steering racks are expensive, even used/rebuilt (300-600), not including install.
Old Jun 8, 2004 | 02:04 PM
badboymel's Avatar
ok I just checked and there is no play but I am losing just a little fluid out of the boots though but I am not really showing any loss in the reserve...
Old Jun 8, 2004 | 02:28 PM
nitromax's Avatar
for the shaking, have the tires rechecked for proper balancing or a bad tire. for the p/s leak, the seal in the rack are the culprit, the boots are only dust shields for the rack. sounds like the damage is done. Lucas p/s treatment may help if the leak isn't too bad. but in reality it's rack time. i don't recommend doing this one yourself if you've never done a rack b4. nissans are a bear!!
Old Jun 8, 2004 | 02:35 PM
badboymel's Avatar
damn I' was quoted like $1200 from nissan YEA RIGHT!! THEY'RE ON A SICK ONE... anyone else have any advice besides pushin my car off a cliff
Old Jun 8, 2004 | 05:39 PM
badboymel's Avatar
anyone!?!?
Old Jun 8, 2004 | 06:45 PM
Ceasars Chariot's Avatar
Old Maxima Legend
a rebuild maybe your looking at 575, new double and add labor
Old Jun 8, 2004 | 07:20 PM
nitromax's Avatar
talk to a friend or relative about their mechanics and service shops they trust and have had good service. nothing like word of mouth ads. call a few local shops , get a feel for what's fair in your area. get good info first then make a decision. you don't have to "kill the car". good hunting!!
Old Jun 9, 2004 | 12:25 AM
izzydig's Avatar
I'd def check ur tires first...make sure they're not out of balance.
Racks are important...and if you're getting alot of wobble from it...I'd worry...but I'd doubt u have a completely failed rack (loose play, etc.). I'd suspect some wobbly tie rod ends first, etc.
Some leakage is normal for older racks. They seem to leak all the time in older max's.
Though if your leak is minimal like mine, then just wait before u have to replace more than 12 oz'z of fluid per year.
If ur on a budget...get a FSM, and rebuild the rack yerself. Tho, its a PITA...and I've never done it...tho I'm considering it. 2 cents.
Old Jun 9, 2004 | 07:17 AM
suli80's Avatar
i had mine replaced about 4 months ago. $500 for a rebulit and labor
Old Jun 9, 2004 | 09:03 AM
badboymel's Avatar
ok thanks guys I knew everyone would come through
Old Jun 9, 2004 | 09:11 AM
MaxedOutOfCash's Avatar
Pizda Boy
i had the same problem...
bought new tires & problem was solved...
Old Jun 9, 2004 | 09:14 AM
badboymel's Avatar
well you know what I do have these POS tires on there called wanli's anyone know of these??
PH98I30
29
Feb 10, 2025 12:03 PM
MAXSE5SPD
Sep 17, 2022 04:00 AM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
