Cylinder 3 misfire what should i check?
Old Jun 12, 2004 | 09:19 AM
95MAXIMASExy's Avatar
my car has been running roughly lately and the check engine light just went on--
i just read and recieved a 6-6 ecu code ( cylinder three misfire). what should i check? obviose choices are the spark plug and coil, i have a multimeter, what should the resistance of the coil be? any other suggestions would be much appreciated. thanks in advance.
-Tanner
Old Jun 12, 2004 | 09:21 AM
96maxdaddy's Avatar
Yep coil and spark plug. If you are having trouble testing it, just move the coil to a different cylinder. If the missfire moves , then its a bad coil.
Old Jun 12, 2004 | 10:20 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
infinite resistance for the coils. you shouldnt get a reading at all. that means its still good. if u havent changed your spark plugs yet, now would be a great time to do them. only use NGK Coppers or NGK plantiums if u have the money. if both are fine, you'll need an injector. if u need one i have some extra ones for $45. contact me @ killcrap@msn.com
Old Jun 12, 2004 | 10:23 AM
Kevlo911's Avatar
Kevlo for President
0603 0604 0605 0606 0607 0608
If one cylinder is misfiring the problem is spark or fuel. A misfire due to a spark problem usually results in a Service Engine Soon light and one of these Diagnostic Trouble Codes:
0608 - Cylinder 1 misfire
0607 - Cylinder 2 misfire
0606 - Cylinder 3 misfire
0605 - Cylinder 4 misfire
0604 - Cylinder 5 misfire
0603 - Cylinder 6 misfire
There are two tests the home mechanic can make, the sound test and the resistance test.
Sound test...
This test is performed with the engine idling. Use a mechanic's
stethoscope or a length of rubber vacuum hose, and listen to each injector.
All injectors should sound alike. If you find one which makes a different
sound (or no sound at all) you have found a problem.
Resistance test...
This test is performed with the engine off. Use an ohmmeter to measure the
resistance of each injector. This does not require removing the injectors.
I don't know the correct resistance value for the injectors on your model,
but they are typically a low number such as 16 ohms. The important thing
is they should all be equal. If you find one injector with substantially
higher resistance than the others, it is bad. If you find one with zero
ohms (short circuit) that is truly unfortunate, because the injector is bad
and it may also have damaged the Engine Control Module (the computer)
because of excessive current drain.
Measuring the resistance of the front bank of cylinders is easy because the
injectors are in plain view. Disconnect the injector electrical connector
for cylinder #2, measure the resistance, reconnect the connector. Repeat
for the cylinders #4 and #6.
Measuring the resistance of the rear bank of cylinders is almost as easy,
but it is difficult to reach the injectors. The resistance may be measured
at a conveniently located electrical connector. Notice the largest,
thickest electrical harness at the top of the engine. This is the Engine
Control Harness and it is shaped like a U, with the open top of the U at the
driver's side of the car. The U has two corners. Look at the corner
nearest the passenger seat. Just inside that corner you will find an 8-pin
electrical connector. This is connector F131. Disconnect this
connector. Now look at the male part, the connector half with the pins
exposed. They are arranged in two rows of four pins.
The pins are numbered 1 - 4 (top row) and 5 - 8 (bottom row).
Measure the resistance of:
- injector #1 between pins 1 and 2.
- injector #3 between pins 1 and 6.
- injector #5 between pins 1 and 5.
Be sure to measure the PINS, not the female receptacles.
The dealer's shop is equipped with high-tech diagnostic instruments. These are wonderful devices but they are expensive and the dealer has to recover his cost by charging you for diagnostic time. Sometimes the home mechanic can do legitimate diagnostic work with nothing more than a ohmmeter and a rubber tube.
To Test Ignition Coils:
With the ignition off, disconnect the electrical connector from the ignition coil. Connect the positive (+) probe of an ohmmeter to terminal no. 1 and the negative (-) probe to terminal no. 2 of the coil connector - the meter should indicate infinite resistance. Reverse the meter leads ( negative probe to terminal no. 1 and positive probe to terminal no.2) - the continuity should be indicated, but not zero ohms. If the results are not as specified, replace the coil.
Connect an ohmmeter between the secondary terminal ( the one that the spark plug connects to) and terminal no. 1 - the meter should indicate infinite resistance. If not, replace the coil.
Note - Ohm meter to test coils is not the most reliable way. Some peoples’ coils tested perfectly, but they still misfired.
Old Jun 12, 2004 | 10:26 AM
killcrap's Avatar
resistance of the injectors should be 10-14 ohms
Old Jun 12, 2004 | 10:27 AM
Maxine's Avatar
Mine did that a while ago when i first bought my car, so i put 93 octane gas in and it came up cyclinder 5 misfire, i was told to let a full tank of gas to be ran through. It cleared up but it still runs rough alittle. So what do i need to do?? sorry to steal your thread
thanks
Old Jun 12, 2004 | 10:33 AM
killcrap's Avatar
thanks
you should always run 93 in a 95+ maxima. check your spark and coils. then check your injector. be prepared to get a few parts such as a manifold gasket, and an injector(contact me if u need one) you'll need to remove the intake manifold to get to the injector
Old Jun 12, 2004 | 10:49 AM
where is cylinder 3?
Old Jun 12, 2004 | 11:14 AM
killcrap's Avatar
center of engine closest to the windshield
ef9
Sep 29, 2015 11:29 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
ballerchris510
Sep 11, 2015 05:29 PM
bbsitum
Sep 11, 2015 04:55 PM
