tranny fluid overfilled??
Old Jun 14, 2004 | 06:09 PM
kbmaxima's Avatar
I checked my tran fluid dipstick and the the mark was way above fill. I wiped it and measured it again on a cold engine.. and the level of fluid was up to the part where the dipstick gets bendy and curvy. Is this a serious problem? Or I can just run with it. Thanks for feedback
Old Jun 14, 2004 | 06:24 PM
Lonely Driver's Avatar
The car was running right? I'd drain it out since it's so easy to remove the drain plug.
Old Jun 14, 2004 | 06:57 PM
maxima98vspec's Avatar
drain it out. it will ruin ur tranny with the quickness
Old Jun 15, 2004 | 03:39 PM
jguillory's Avatar
Make sure you check the fluid level with the engine running (and warmed up), after having driven around for a while in all gears so the tranny fluid is flowing around. Then you're really supposed to move the auto shift selector through all the gears, I think. This may give you a more normal reading...
Old Jun 15, 2004 | 08:15 PM
joeynym's Avatar
Back in the Max
^^^^100% true^^^^^^
Old Jun 15, 2004 | 11:37 PM
NightRider's Avatar
Originally Posted by joeynym
^^^^100% true^^^^^^
100% untrue. The hydraulic pump will purge unused tranny fluid if the pan is overfilled. That's what that hose is to the right of the front valve cover that isn't connected to anything.
Old Jun 16, 2004 | 03:22 AM
98maximaSS's Avatar
so night rider your telling me the tranny fluid will spray all over my engine intake and probly my radiator just cause i overfill the tranny ( ididnt know that) i thought that hose was some sort of a breather hose
spencerwh1
Jun 30, 2016 05:44 AM
fx4five
Oct 18, 2015 06:57 PM
Need help
23
Oct 2, 2015 08:56 AM
fx4five
Oct 1, 2015 04:58 AM
