Rough idle, hard starts, and lack of performance when under full throttle.annoying
Old Jun 17, 2004 | 04:15 AM
infinitiblast's Avatar
Well I've been having this issue of it taking at least 3 trys to get my car to start. Then once I do get it started and it warms up at normal idle speeds the car just sits there and blips like I have a cam in the thing. I can see the rpm's jumping from around 500-700 constantly. I've also notice under full throttle conditions the car has become very lack luster in power. Once I'm on the highway and rolling everything seems honky dorey for the most part.
Things I have done to try and fix the issues
-Replaced plugs
-Cleaned IACV
-Cleaned Stillen intake
and withing the past three months
I have...
-Replaced all the injectors
-Replace the knock sensor
Coil packs are not that old so I know thats not the issue. The only code I have on the cel light is p1706 which is excessive speed in park..which is stupid cause I have a manual...but turns out someone said thats just the nuetral safety switch.
Anywho any other ideas folks?
Old Jun 17, 2004 | 04:49 AM
Kevlo911's Avatar
Kevlo for President
So you have replaced teh coil packs too?
Old Jun 17, 2004 | 05:57 AM
Yep....................
Old Jun 17, 2004 | 09:16 AM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
did you clean your TB?
Old Jun 17, 2004 | 09:20 AM
Maximum96's Avatar
MAF sensor or tps
Old Jun 17, 2004 | 09:22 AM
Yep cleaned the throttle body.
Maximum96 yeah I was thinking about the maf thing as well.....
Old Jun 18, 2004 | 06:33 PM
88MaximaSE's Avatar
lala
99% of the time this isn't the damn reason
Old Jun 19, 2004 | 08:08 AM
Jay93SE's Avatar
Check your fuel pressure. The pump may be on it's way out. I had the same issues for months and replaced everything you did, except for the coils. One day I shut the car off and she wouldn't start again. I spent 2 hours diagnosing wires and relays, until I was satisfied that the pump really was dead. I replaced it and she runs better than ever.
Old Jun 21, 2004 | 10:49 AM
88MaximaSE's Avatar
hey
i think my fuel pump is about to die. seems like between the hards starts and the momentary stutters in acceleration have to be the fuel pump. how difficult is it to replace and where can i get a cheap fuel pump. how good are those adjustable fuel pumps.?
Old Jun 21, 2004 | 02:19 PM
Terran's Avatar
How do you check fuel pressure? I kind of think mine might be dying. It might be my imagination, but it seems like when my fuel is low the car is slower (which shouldn't be the case since the car is lighter on low fuel).
Here's a writeup on replacing the fuel pump http://vbxmaxima.8m.com/fuel%20pump.html
Old Jun 21, 2004 | 02:37 PM
Gen8888's Avatar
I'm having the same type of problem as well. After 2-3 tries, the car finally starts and has a rough idle for a second than runs perfectly fine. I've checked alot of things and still cannot diagnose the problem. Things i've checked,
injectors
fuel pressure
starter
ground for the wires
sensors
battery
alternator
throttle body
ECU
some other miscellaneous things. The dealer says that the car does spike below 9amps on start up, so maybe it is a short somewhere but I don't know where to begin. Hopefully you get ur problem solved, because i'm clueless with this problem. I am getting codes of 1008 and 1302 but they don't have anything to do with this starting problem I believe.
Old Jun 21, 2004 | 04:44 PM
njmaxseltd's Avatar
P1706 points to a faulty Park/Neutral position switch.
You might want to change that switch, it's on your transmission. If the ECU thinks the car is in neutral or park for that matter, it may run a completely different ignition and fuel mapping program being the engine is not under a load. That can cause drivability issues just as your describing.
Don't over look the obvious, the ECU might be telling you whats wrong....
Old Jun 22, 2004 | 08:15 AM
Gen8888's Avatar
bump......
Old Jun 23, 2004 | 04:23 AM
Well I'm 5spd so not sure if that still applies. Secondly to those talking about possible fuel pump issues.
Once it does start for about 5 seconds it burns ecessive fuel out the tail pipe (darkish black smoke) and you can smell it as being really rich.
So I know its getting plenty of fuel.
Old Jun 24, 2004 | 06:13 PM
ThurzNite's Avatar
I'm gonna try SeaFoam tomorrow. Maybe it'll resolve some of my symptoms, which kinda sound like others here.
Jae
Old Jun 27, 2004 | 07:04 PM
f550maranello2's Avatar
if you are getting black smoke out your talik pipe check your fuel pressure regulator
Old Jun 27, 2004 | 07:10 PM
cardio175's Avatar
YOu didn't run a scanner yet? Is your check engine light on?
Matt93SE
May 24, 2019 02:58 PM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Maxboy23
Aug 11, 2015 11:59 AM
