clutch fluid
Old Jun 23, 2004 | 08:14 AM
shibbys's Avatar
clutch fluid
what type of clutch fluid does a 96 maxima se 5spd take? mine is completely empty, i think i might have a leak.
Old Jun 23, 2004 | 08:23 AM
shibbys's Avatar
also do u have to bleed any lines or anything?
Old Jun 23, 2004 | 08:28 AM
Nismo's Avatar
Dot3 brake fluid, there are 2 bleeder screws, one on the tranny slave cyl and one on the right side shock tower.
Old Jun 23, 2004 | 08:29 AM
Ladzio's Avatar
Use Regular DOT 3 brake fluid. If your fluid reservoir is almost empty, most like ly you have air in system. So you better bleed it. The nut is located on slave cylinder to bleed teh system.
Old Jun 23, 2004 | 08:31 AM
shibbys's Avatar
is it hard to bleed the system? do i have to jack the car up?
Old Jun 23, 2004 | 08:33 AM
Nismo's Avatar
no you can leave the car on the ground, If you dont have one of those automatic bleeders, you need 2 people, one pumping the pedal and the other turning the bleeder screws to catch the fluid in the catch can
Old Jun 23, 2004 | 08:40 AM
shibbys's Avatar
do i have to use both bleeder screws?
Old Jun 23, 2004 | 08:58 AM
shibbys's Avatar
by right side do u mean passenger or driver side. pics would help alot, i dont know what bleeder screws look like.
thanx
Old Jun 23, 2004 | 09:14 AM
shibbys's Avatar
bump please
Old Jun 23, 2004 | 10:05 AM
shibbys's Avatar
can someone please give a little more detail on bleeding the clutch, i got court to go to for one of my speeding tickets.
Old Jun 23, 2004 | 11:08 AM
Nismo's Avatar
here http://www.motorvate.ca/mvp.php
go to transmission, then click "clutch bleeding"
Old Jun 23, 2004 | 11:09 AM
Jay93SE's Avatar
Maybe you're better off without a working clutch.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
Need help
23
Oct 2, 2015 08:56 AM
carlosvq30
Sep 26, 2015 09:44 AM
