squeal when engine is cold
Old Jun 23, 2004 | 07:14 PM
xxdean057xx's Avatar
what can cause this? myn car has a little squeal when its cold but seems to stop when the car warms up.
Old Jun 23, 2004 | 07:27 PM
Nick7455's Avatar
When starting....when idle or when driving at low speeds/high speed???? EXPLAIN URSELF
Could be starter/belts/few other things....
Old Jun 23, 2004 | 07:50 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
sounds like a belt problem, either your belts are loose or are worn, adjust tension w/ the tensioner, be sure you're within spec & don't overtighten, if that doesn't help, then you need new belts
Old Jun 23, 2004 | 08:12 PM
Prophecy1's Avatar
I going to guess belts. WhT98SE has good advice. Ther is also some belt grease as well you should check that out. Im thinking of worn belts.
Proph
Old Jun 24, 2004 | 03:49 AM
Kashoggio's Avatar
next time it happens open your hood.. and spray some wd40 on the belts , if the noise stops then you have figured out your probelm.
Old Jun 24, 2004 | 04:09 AM
n2oMike's Avatar
Just be sure to loosen the 14mm nut on the tensioning pully before cranking the adjuster... or that adjuster will break.
The Haynes manual does not mention this nut, but trust me, that's what will happen.
Good Luck!
Old Jun 24, 2004 | 07:31 AM
95stillenmax's Avatar
sounds like your belts too me
shilov
Feb 19, 2024 09:40 PM
seesole
Sep 14, 2015 12:38 PM
tardrex
Sep 11, 2015 07:35 PM
ballerchris510
Sep 11, 2015 05:29 PM
