auto tranny mod??
Old Jun 24, 2004 | 07:25 PM
maximus_pr's Avatar
auto tranny mod??
reading and article in www.nissanperformnacemag.com it mention something about doing something to the tranny to improve shift heres the article anyone knows anything about this mod.
Other ideas to improve shifting with an auto tranny could be to shim the PL solenoid regulator springs to increase peak pressure or to shim the shift accumulator springs to firm up and speed up the shifts. Or you can just swap in a manual! from- www.nissanperformnacemag.com
Old Jun 24, 2004 | 07:53 PM
A32Matt's Avatar
yeah, i did the mod. definately improves your shifting, i've been able to chirp 1st and 2nd. i have it hooked up to a rocker switch that i can activate whenever i want.
Old Jun 24, 2004 | 09:02 PM
THT's Avatar
THT
Throbbing member
Mine's by the throttle linkage and activates only at WOT. Great mod for the money. Jime says it causes the tranny to shift as fast as, if not faster than the VB mod that costs hundreds of dollars.
~THT
Old Jun 25, 2004 | 01:00 AM
maximus_pr's Avatar
i'm not talking about the drop resistor i did that it mention something else on the article
"Other ideas to improve shifting with an auto tranny could be to shim the PL solenoid regulator springs to increase peak pressure or to shim the shift accumulator springs to firm up and speed up the shifts"
thats what i want to know
Old Jun 25, 2004 | 01:01 AM
maximus_pr's Avatar
btw i have very same switch bough it at radio shack
Old Jun 25, 2004 | 04:14 AM
ParaMax's Avatar
Ok guys... I'm an idiot... Where can I find the write up for this Drop Resistor Mod?... I know it says Maxima.org, so I'll check there. I'm just wondering if there was also a write up here at the forums side.... Ah well. I'll look into it
EDIT: Ok... I looked around and didn't find anything.... Could someone pretty please save this idiot!
Old Jun 25, 2004 | 04:31 AM
erty67's Avatar
Decal Specialist
drop resistor mod = bad for tranny
VB mod = good for tranny
Old Jun 25, 2004 | 06:06 AM
THT's Avatar
THT
Throbbing member
Got any proof or reasoning to back up your claim, erty67?
~THT
Old Jun 25, 2004 | 07:25 AM
maximus_pr's Avatar
shim the PL solenoid regulator springs ????
shim the shift accumulator springs????
anyone have done this or know how to
Old Jun 25, 2004 | 07:40 AM
A32Matt's Avatar
how can the drop resistor be bad for the tranny if it does the same thing the VB does? they both quicken and firm up the shifts, the only thing i can think of that would be bad is if you have a weak line, the high pressure could blow it...but you would know that the second you went full pressure.
Old Jun 25, 2004 | 07:47 AM
NismoMaxman2's Avatar
The only 4.5 gen in da 956
I have a VB mod, and it works great, do the DROP RESISTOR and tell me how you car is a in a couple of weeks. Its not good for the tranny, you at least need a tranny cooler first of all. But I think doing the Drop Resistor mod, is excessively wearin the tranny, your not letting the car shift on its own, and your messing with the cars electrical parts. I might not know much, but i think its a bad idea doing the Drop Mod, but I know a ****load of people can say they've done it for years w/ no ill effects. and yet theres anothe ****load saying its f*cked up there transmission.
Old Jun 25, 2004 | 07:51 AM
tweeter007's Avatar
They don't to the same thing. The Vb mod actually involves rebuilding components in your VB and mechanically changing the shift points, line pressure,slippage, racers have been doing it for years to improve shifts.Drop resistor just takes away a function of the transmission that it needs to operate "properly". Drop resistor is the "poor mans" tranny mod(you'll be even poorer when your tranny blows),VB mod is the right way to go about it.If you research this a bit on the org. you'll find the proof you need.
Old Jun 25, 2004 | 08:12 AM
maximus_pr's Avatar
ok enough of the drop resistor i wnat to know about the other stuf mentioned in the article
Old Jun 25, 2004 | 12:49 PM
maximus_pr's Avatar
ten character bump
Old Jun 25, 2004 | 07:09 PM
ParaMax's Avatar
I'm super lost... Is the VB Mod write up in one of the Stickies?.... Or do I have to find it elsewhere?
Old Jun 25, 2004 | 09:00 PM
erty67's Avatar
Decal Specialist
~THT
info for your pleasure...
http://forums.maxima.org/showthread....highlight=drop
http://forums.maxima.org/showthread....light=resistor
...plus i know two people that had serious tranny issues after trying the drop resistor mod.
Old Jun 25, 2004 | 09:03 PM
erty67's Avatar
Decal Specialist
I don't think there's a write up. The VB mod requires replacement of the Valve Body. ...or tranny shops can modify yours. I got mine from Maximum Tuning and I love it.
Old Jun 26, 2004 | 02:19 AM
DaBombX's Avatar
Hasn't this issue been talked a lot before?
VB mod is definately good, but I don't really care for the harshness all the time.
DR mod basically does the same thing but should only be used at WOT.
I've got dual switches for my DR mod.
On/Off switch with a WOT switch.
Works great for me.
Old Jun 26, 2004 | 02:45 AM
Jime's Avatar
There is no proof that the DR Mod or VB Mod shorten or lengthen the life of the tranny period.
When replying to a discussion:
Don't give tech advice unless you have first-hand knowledge or experience of the subject.
Saying so and so did or said is NOT first hand knowldege.
Link to the answer and try not to guess the answer to a question.
If you are not completely sure about your answer, be sure and state that in your reply.
The goal is to not spread hearsay or bad information.
Old Jun 26, 2004 | 05:51 AM
erty67's Avatar
Decal Specialist
thanks for the lesson. Sorry guys, but yes I am NOT a Transmission professional. I only said that based on what I have heard over my last 3years on this site. Based on my NON-professional experience, I decided to do a search and give you guys something to read and make your own decision on, verse making up my own stories. I did NOT mean to mislead you. Sorry if I came across that way. Have a nice day.
Old Jun 26, 2004 | 01:18 PM
ParaMax's Avatar
Arigatou Gozaima****a
Old Jun 26, 2004 | 02:54 PM
tweeter007's Avatar
My mechanic/friend (owner of a garage,stock car racer) who helped me install the VB mod, told me before I even told him what I was installing that the reduced clutch slippage and harder shifts that I was looking for, contrary to what most might think,will actually lengthen transmission life. If you own a 5 speed you change the clutch multiple times troughout it's life, if your auto's slipping you need a new TRANNY. Transmission just becomes more durable/capable to handle the extra mods (especially SC) and our tendancy to floor it all the time!
fx4five
Oct 18, 2015 06:57 PM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
