how much slower will i be after i install 18's?
Jun 27, 2004 | 04:04 PM
since everyone is tellin me that my max will be slow after i get 18's to replace my stock 16's.....how much slower will i be? will be equivilent to having 2 people 100lb people in my back seat?
Jun 27, 2004 | 04:07 PM
I really cant give u specific number but i can tell you that after i added my 19's my takeoff suffered pretty badly, up top there was not much difference that I could take notice of. Hope that helps
Jun 28, 2004 | 02:09 AM
I have 18's too, you can definitly feel a difference bottom end. You have to remember that you are moving much more mass with the same drivetrain. It will slow you down a bit. I don't have any numbers for you either. However, I sitll beat up on Hondas!
Jun 28, 2004 | 04:46 AM
weigh one of your 16 inch tire/rim combo and then weigh the next tire/rim combo and see how much weight you are adding per tire/rim.
ricer math
take that total and multiply times 4 ____
Take your total and multiply time 10 _____
then you will be close to knowing how much slower the car will be. if you gain 200 lbs, then your .2 slower using the old for every 100 lbs you add it will set u back a .1 at the track.
well im heading back to riceville, later on !
Jun 28, 2004 | 06:55 AM
hell i have heavy 17's and i can teel a huge differance.
Jun 28, 2004 | 09:37 AM
i guess i will be honked at at red lights cuz im about to order some 28.5 lbs 19"s soon ! RIM ONLY !
BUMP, time for a low end mod. what u guys recommend besides the ECU?
i understand that we will need TORQUE to pull these rims and TORQUE is created by restriction, so whats a good low end mod to pull some heavy rims ??
Jun 28, 2004 | 10:41 AM
It depends on which 18s you get. There are some heavy ones and some light ones like BBS CHs.
Jun 29, 2004 | 05:25 AM
Quote: i guess i will be honked at at red lights cuz im about to order some 28.5 lbs 19"s soon ! RIM ONLY !
Your gonna be running more than a 60lb wheel tire combo
Your gonna have to go boost to make up for that. I bet your car wouldn't make it out of the 17's at the track with those things on.
