Oil pressure light at startup
Old Mar 31, 2001 | 11:33 AM
max808's Avatar
On startup my oil pressure light stays on for about 2 seconds, which is normal, then goes out. Then about 1 second after, it goes on again for 1 second. I was wondering if other had this experience? Thanks.
Old Mar 31, 2001 | 01:13 PM
Daniel B. Martin's Avatar
This is not normal.
The first thing to do is verify that the engine oil is up to the FULL mark,
that the oil is of the correct viscosity, and that it has not become diluted
with gasoline. If these criteria are met, proceed with the test procedure
(below).
The dashboard oil pressure gauge is either accurate or inaccurate. The way
to find out which is to install a "known good" oil pressure gauge, start the
engine, let it come to normal operating temperature, and take the pressure
reading. This test gauge is installed in the engine compartment, not in
the dashboard. This is not a complicated test and should take only an
hour, start to finish.
If the test gauge confirms low pressure at a warm idle you have a
mechanical problem which must be repaired soon. This could be a worn oil
pump, worn engine bearings, or a defective oil pressure relief valve.
If the test gauge shows normal pressure at a warm idle you have a defective
dashboard gauge or oil pressure sensor.
305head
Aug 26, 2015 09:03 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
