Replace ECU?? Error code 31, 95 SE
Old Jul 5, 2004 | 12:23 PM
High Desert 95SE's Avatar
Help!
The check engine light came on. I went to vbxmaxima.8m.com and was able to get the error code: 31 on the MIL.
Code reads:Replace ECM (ECCS control module). (Chilton)
Do I need to replace the ECM? Is there a difference between the ECM and the ECCS?
Is there some other diagnostic test necessary? Do I also need an ODB2 scan?
Finally, should I replace the ECM with a rebuilt or go to a salvage yard?
Please forgive my lack of knowledge. Just a girl with a Maxima....
Thanks for your help.
Old Jul 5, 2004 | 12:28 PM
Kevlo911's Avatar
Kevlo for President
www.car-part.com
Find one same year and tranny.
But first reset the ECU and see if the code comes back.
Old Jul 5, 2004 | 01:05 PM
ECU won't reset
Originally Posted by kevlo911
www.car-part.com
I tried without success to reset the ECU. The check engine light will not go away.
Any ideas?
Old Jul 5, 2004 | 01:41 PM
X5Runner's Avatar
Originally Posted by mwolfe
Help!
First of all, code #31 is only applies to 93-94 model year (OBD-I). 95-99 you have to trace the codes via OBD-II, and if I remember correctly, then there's only one code that contained #31 is P0131 = Front O2 sensor (Right bank). Second, ECM = Electronic Control Module. I don't know what's ECCS stand for, however, I know exactly there's a contact relay called ECCS that control both camshaft position sensor and some other power train control solenoids. You may take a quick look at the ECCS fuse. It's located in the fuse box under the hood, on driver side fender, and it's very close to the battery. Anyway, I may give ECCS a name; ECCS= Electronic Contact Control System.
Old Jul 5, 2004 | 01:56 PM
Kevlo911's Avatar
Kevlo for President
NO, 31 = 0301
You don't get PXXXX thorugh the screw method, only by useing an OBDII scanner.
She read the ECU correctly.
Sadly, I believe you will have to replace the ECU. Start looking on www.car-part.com and in the forsale section of this forum.
Like I said above, find an ECU same year and tranny.(But for you a 96ECU will work)
Or if you want to make your car faster you can buy an aftermarket ECU from JWT or Technoquare.
Old Jul 5, 2004 | 02:25 PM
Thanks for the info
NO, 31 = 0301
Thanks again for your help.
I have managed to reset the check engine light.
I am on my way now to check car-part.com for a replacement.
mrc00l88
Jan 25, 2024 01:14 PM
lux97Max
19
Aug 27, 2015 07:48 PM
Maxboy23
Aug 21, 2015 11:02 AM
maxima297
Aug 3, 2015 12:50 PM
