axle seals
Old Jul 12, 2004 | 08:07 AM
JeEvE's Avatar
axle seals
I have the tranny out and Im trying to replace both axle seals. I ordered both seals from JRNissan but I wasnt positive of the part numbers. The passenger side seal looks like the right one but the seal I got for the drivers side looks a lot bigger. Is that the correct one for the drivers side? If not, what is it for?
Heres a pic...
Left - Passenger side Axle Seal: 38-342-81X01
Right - Driver side Axle Seal:38-342-51E00
Old Jul 12, 2004 | 09:04 AM
oldngivout's Avatar
Willing to learn
I can't verify the part numbers off hand, but I can tell you that the seals you have pictured look correct.
The LH is way bigger than the RH.
I put them in mine while the trans was out, but I did not fix the bearing clearance issue that causes them to leak.
Guess what...... they still leak.
Old Jul 12, 2004 | 09:19 AM
JeEvE's Avatar
I dont think mine were leaking but Im worried about the bearings. A lot of people seem to have that problem. Im just going to try and get a 2k or 2k1 tranny soon because my third gear is getting messed up. Im got the passenger side seal out easily but the drivers side just doesnt want to come out. I tried using a screwdriver and pulling on it with some pliers but its stuck in there. Anything else I can try?
James92SE
142
Jan 2, 2024 09:23 AM
Mar 12, 2020 12:06 AM
mpbclutch33
Dec 26, 2015 11:11 AM
RealityCheck
Oct 2, 2015 06:34 PM
The Wizard
24
Oct 1, 2015 08:47 PM
