fuel filter for 97 max..
i have a 97 max and did some reading on the fuel filter. they said the 300zx fuel filter is better, but however it may not fit in the brackets.
what is recommended and what do you guys use for ur fuel filter?
what brands and where can i get theM? i've only noticed fram.
anyhow thanks..
anyhow thanks..
get the 300zx twin turob filter oem fiulter. they are pretty cheap about the same price as the max's filter.
the twin turbo filter is bigger. there really is no performance differance in all these filters, just the twin turbo's filter is suppose to last longer cuase of it's size. thatis what the parts guy at the dealer told me.
I recently replaced mine
anyhow thanks..
anyhow thanks..
http://www2.autopartsauthority.com/p...rt=Fuel+Filter
The replacement sucked! It took me forever to get the friggin hoses off, so my advice (as was given to me by some of the chaps here)...
*Run the car a little before you swap the filters, the hoses will warm up and make life A LOT easier
*Take your intake out, this will give you more room to work
*Pull the old filter from the bracket so that you can get a better handle on it when you are disconnecting the hoses
*Finally, Twist off the hoses, don't pull... I tried pulling first and I thought I was gonna sh*t my pants I was pulling so hard...
If you do all of the above, should only take you about 20 minutes. Good luck!
Yeah, the hoses like to stay stuck. I used a flathead screwdriver (or a putty knife would work) to pry the end of the hose away from the body of the filter. Then once I broke it loose, used long angled needle-nosed pliers I gently pryed them off using the filter canister to push off from. Go to harborfreight tools local store or website and add the bent-nose pliers to your toolbox if you don't have them yet. I use them as often as my 10mm ratchet wrench (which is a lot).
It may pay off really well to put some of that anti-stick stuff for radiator hoses on for next time, but make sure it's safe for use in fuel lines.
First time doing it with regular needle nosed pliers, it took me over an hour. Second time, as described above, 15 min and I was being slow.
Dave
Dave
Mine came off pretty easily. What I did was pull the fuel pump fuse and try to crank the car and let it run until it quit. Then I tried cranking it a couple more times. I believe by doing this it releases the pressure in the fuel system and makes the hoses easier to come off. It worked for me
Sorry Joew I dont have the oem part number.
i don't think i have abs.. i have a 97, which trim i dun even know =I .. noobs anybody can help me? i don't think the manual says.
so the 300zx fits the bracket easily?.. i can just visually see it when i open my hood, but i don't even know if what i see is the fuel filter. ( i just quick glanced at it and see black hose in and out of it.
there's a checker's and napa here, checker's sells fram brands.. does anyone know where i can pick other brands up?
but first is to narrow down if i should get the 300zx one or the 97 max one. does any year of the 300zx matter?
anyhow thanks.
anyhow thanks.
if you don't want to get OEM then 97 should be fine. note that the price oem fuel filter is about the same as aftermarket. i would recommend J&R nissan but you live in HI. i'm not sure if shipping cost would make a dent in your wallet.
i haven't changed my fuel filter for about hhhmmm.....3 or 4 years.....i didnt even know it needed to be replaced.....does it affect performance or anything like that? either way im going to the store right now to get me a tt 300z filter
I don't think anyone will say it offers better performance. The filter will only last longer. If anyone would like to change your fuel filter more frequently then Maxima filter is for you.
Originally Posted by DAVE Sz
^ yeah, ok. A 300zx fuel filter for a 300zx will cost you $30 at ANY local dealer. Max filter is $15 which isn't much better. Find a DISCOUNT nissan dealer.
jmlee44
Oct 2, 2022 02:13 PM
Forge277
Jun 13, 2016 09:26 PM
