Maybe a bad wheel bearing?
Old Jul 23, 2004 | 03:09 AM
toofast240's Avatar
Hello all,
I have this weird noise coming from my front left rim. It sounds like someone is rolling a tire across a rubber floor and it souds like it rotates with the tire. Sort of a whump, whump, whump, but with the rubber on rubber sound. I thought it was my wheel bearing, but on all of the sites where everyone says the wheel bearings are out, it is described as a high pitched squeal. I have 107k miles on my max and was thinking it is about that time for the wheel bearing. ANy help would be greatly appreciated.
Old Jul 23, 2004 | 05:25 AM
maxdis1's Avatar
Ok, from my experience a high pitch sound was not my indication ,but rather a whirring sound, i.e whirr-whirr-whirr. You should jack the car up on the side that you are hearing the noise and shake the wheel left -right , using both hands to see if there is free play . Most use this test as an indicator.
Did you change tires recently? If so then new rubber sometimes increase road noise. The bearing is cheap , the labor is going to hang you.
Good luck and try not to pay too much if you are not using alternative methods to press the bearing out . I hope someone gives more indepth input than I did.
Old Jul 23, 2004 | 07:40 AM
Wil's95SE's Avatar
我爱台湾
Originally Posted by toofast240
Hello all,
You nailed it right off the back. it is your wheel bearings. I replaced my fronts around the 105K mile mark and my rears around the 110K mile mark, that's about the time you'll notice them starting to go bad. Mine wasn't a high pitch sound like I hear others have experienced. Mine sounded like whump, whimp, whump, and got louder the more you accelerated and became very noticible as you hit the brakes. Depending upon if you can do it yourself or have someone else do it for you the front wheel bearings you can get from any autoparts store (I went to Pep boys and it cost me $35 for 1) . The rear I had to go to the dealer and it was a lot more (I believe around $100). Check around and see if someone is cheaper than that. Hope this helps.
Old Jul 23, 2004 | 09:46 AM
FormorAccordMan's Avatar
sdfdafsdfa
Old Jul 23, 2004 | 12:38 PM
knight71's Avatar
A Defective tire also sounds like a bad wheel bearing..Check the tires 1st b4 u spend some $$ on a wheel bearing.
Old Jul 23, 2004 | 01:07 PM
toofast240's Avatar
Thanks for the input everyone. I really appreciate it!
I<3 A32's
Sep 10, 2015 11:07 AM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
boomerbrian
Sep 4, 2015 08:25 AM
maximusrising
Sep 2, 2015 09:55 AM
