engine temp. gauge
Old Jul 25, 2004 | 01:25 AM
Maximus_95's Avatar
engine temp. gauge
ok guys, i was driving normaly, then i noticed that my temp. gauge was all the way up, and i mean past the second line on top.
pulled over, my engine was not smoking, just normal temperature.
had enough engine coolant and everything.
then i kept driving, wouldn't go down, i noticed though, every time i tapped on the gas, the needle would go down and up like fast, but it still stays up there. does anyone have any idea what might be wrong?
thanx.
Old Jul 25, 2004 | 06:30 AM
mzmtg's Avatar
Minister of Silly Walks
How did you know your coolant temp was fine? Just because there was no smoke coming out or anything doesnt mean it's not overheating.
Old Jul 25, 2004 | 09:10 AM
Kevlo911's Avatar
Kevlo for President
Do your radiator fans turn on??
Old Jul 25, 2004 | 09:29 AM
Guttermouth's Avatar
You might just need to replace the relay (or hit it a little bit, hehe) if your fans aren't coming on. That could explain why the temp is up, but the coolant level is fine.
Old Jul 25, 2004 | 07:19 PM
Maximus_95's Avatar
actually everything is fine, fan is working, coolant was added. the thing is, the needle was not just up to the 2nd line on top, but it surpassed the limit, its like pointing all the way up.
whenever i tapped on the gas, the needle would quickly go down and up like in half a second, its not just gradually going up.
Old Jul 25, 2004 | 10:24 PM
geo1317's Avatar
im having the same problem, and i think its the temp sensor for the gauge. there are two sensors one for the ECU and another for the gauge. so the car will be running fine but the gauge will show that it running hot.
Old Jul 25, 2004 | 10:26 PM
1FSTMAX's Avatar
When brian had the car he was having the same prob. I thought he fixed it.. I have an extra coolant temp sensor if you need it..
Old Jul 25, 2004 | 10:37 PM
geo1317's Avatar
you are talking about the one for the gauge right? if you are send me a PM.
Old Jul 27, 2004 | 12:40 AM
Maximus_95's Avatar
hey, this is my thread, haha, how much are you asking for it?
Old Jul 28, 2004 | 06:21 AM
Max Atlanta's Avatar
[FONT=Times New Roman][SIZE=7][COLOR=DarkOrange]
The same thing happened to my '99 about two years ago. I brought it to a shop and they replaced the sensor thing under the hood and it still did it. They kept the car for three days and it never over heated. To date no one I have asked has been able to figure it out. On a cold winter day the needle will shoot all the way up when the car is first started...after sitting in freezing or below freezing weather all night. My car has run and continues to run perfectly so I just ignore the temp guage. It will actually read the correct temp about 10% of the time when running.
I can't figure it out and I don't want someone digging around my girl and possibly messing something up. She has 142,000+ and runs like a champ
Old Jul 28, 2004 | 04:08 PM
Maximus_95's Avatar
ok guys, weird, my engine temp. gauge is back to normal after i boned out last night after running a wrx. weird. thanx for the help though.
Old Jul 28, 2004 | 05:13 PM
1FSTMAX's Avatar
I'm talking about the stock temp sender unit..
Umm i paid like 15 buxs.. ill let it gor for ten..
captchaos
Mar 15, 2016 12:18 PM
RWCreative
Sep 21, 2015 11:01 AM
BrandonCause
Sep 14, 2015 10:41 PM
kadespraggins
Sep 14, 2015 12:04 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
