Can a bad camshaft sensor prevent a Max from starting?
Old Jul 26, 2004 | 12:08 AM
miladey1's Avatar
Hello all,
I have a 95 max, and 9 out of 10 times, the car starts. But sometimes, the car wont start over. It cranks, but no fire.
A while ago the check engine light came on and I did the ECU Code, and it was 1-1 which is camshaft sensor, but the check engine light went away and am not getting the camshaft code anymore when I do the test.
What do you guys think, can it be the camshaft sensor??
Thanks,
Miladey1
Old Jul 26, 2004 | 03:39 AM
miladey1's Avatar
Anybody?????????
Old Jul 26, 2004 | 01:19 PM
nismology's Avatar
Yes it will prevent it from starting. Just to prove that, disconnect the harness from the sensor. The car will crank but NEVER start...
Old Jul 26, 2004 | 01:35 PM
njmodi's Avatar
Do I get a tax break?
to that... yes it will. A new camshaft sensor will cost about 50-60 bucks from jrnissanparts.com. Replace it or order it so you have it handy in case your car stops starting altogether.
Old Jul 31, 2004 | 05:51 AM
aclough's Avatar
Same thing happened to me--replace the sensor!
Old Jul 31, 2004 | 06:32 AM
twiggy144's Avatar
Me too. I disconnected the sensor. The engine cranks without starting.
Old Jul 31, 2004 | 07:55 AM
meccanoble's Avatar
Sports Button FTW
iight, i just suffered from this thing. For one, your car can still start. But it will cut off very shortly. I had a bad or going bad camshaft sensor and if car rested for a few minutes it would start up fine but after a few minutes of driving, rpms drop and car wont start, not even from a roll. So yea they are all right . Easiest thing in the world to change though, and u would most likely get a code for it, cause i know i did.
kjlouis
Nov 24, 2018 06:09 AM
Rage Maximus
Sep 3, 2015 12:26 PM
doobadoo
Aug 15, 2015 06:43 PM
wingnut2006
Aug 15, 2015 04:16 PM
Balkins
Aug 12, 2015 06:39 AM
