AMSOIL - Synthetic Oil. How good is it?
Old Apr 4, 2001 | 09:34 AM
maxnewbie's Avatar
I've read up on this new synthetic oil and its claims may warrant some attention. Anyone out there have any experiences using this oil? What is your opinion? You can read the claims for yourself at www.amsoil.com
Old Apr 4, 2001 | 09:48 AM
Kenneth's Avatar
OG :)
Best!
Old Apr 4, 2001 | 10:14 AM
VQMaxSE's Avatar
I started using it in my car when I purchased it, 2 months ago. I have almost 60K on the car now and use their oil, oil filter, air filter and transmission fluid. Now I only have to change my oil once a year! (filter every 6 months) and I save money compared with other synthetics. It is the oldest and best synthetic oil IMHO. Do some research and make an informed choice.
ps. if you decide to go with AMSOIL you can get a preferred membership for $10 that will save you over 20% on your purchases for 6 months (or $20 for a year). It is worth it if you intent to spend over $50.
Old Apr 4, 2001 | 10:21 AM
maxnewbie's Avatar
Amsoil - Which one?
Which Amsoil brand do you use on your Max? They've got the Series 2000; SAE 10W-30XL-7500; or SAE 10W-30 Synthetic.
Old Apr 4, 2001 | 10:33 AM
Jeff92se's Avatar
I'm needing a caw
Search will reveal more information than you could handle. Amsoil is very good. But so is Redline and Mobil 1. The biggest difference is between syntetics vs dino oils, not between different synthetics. Search+research+reading=your own informed decesion.
Old Apr 4, 2001 | 10:54 AM
EdwardCYH's Avatar
from bimmerforums.com
http://self.phpwebhosting.com/~bimme...=&threadid=416
After analyzing all the data and discussing different oil properties and related subjects (that were not part of my "oil study") with some of the enginners at a few of the oil companies, I have made up my mind which oil I will be using in the M3.
My viscosity grade choices were the 0W-30, 5W-30, 5W-40, 10W-30 and 10W-40 oils. My "short list" choice of product manufacturers were Amsoil, Redline and Mobil.
I have elected to use Amsoil's 0W-30 oil.
The reasons for my choice are many.
In discussions with Mr. Darren Wallace (Technical Design Engineer and Chemist) of Amsoil Company, he suggested strongly I use the 0W-30 in the M3 for street and track. His suggestion rather suprised me! I asked him, "track too" and he said "most definitely." I will only lightly attempt to explain why he made his suggestion to me.
He explained that BMW engines, as are most others, had very tight engine tolerances for their bearings, etc. He said using the Amsoil 0W-30 would protect these bearings (and the entire engine) better than ANY 30 weight grade oil they have ever tested, including their other 30 weight multi-vis grade oils they offer. The anti-wear additive package for this 0W-30 oil, he said, is simply the best they have ever seen! The chemical make-up of the other Amsoil oils don't allow this same anti-wear package to be used. He also explained this particular oil is better at dealing with the contaminents (hydrocarbons left from combustion), dirt and corrosion, etc. than the other oils.
He said using the 0W-30 would offer unheard of protection at dry start-up where the anti-wear properties, only found in Amsoil's 0W-30, would virtually eliminate the metal-on-metal damage incurred when first cranking up an engine. He further explained that damage results whenever an engine is first cranked up, even if the ambient temperature is 100 degrees F.
There is much more to the anti-wear abilities of this "one oil" but I won't attempt to even try to cover it all. He did admit that no other oil that they have in their line of products, as good as they all are, has the characteristics, properties, abilities, traits and technology that the 0W-30 does. In fact, the way he put it was, "the Amsoil 0W-30 could be five years ahead of the competition!"
He also added that all 0W oils are more expensive to produce and this is the reason most other synthetic oil producers don't offer 0W oils. In the future, he said, this will change in his opinion.
Mr. Wallace further said that this oil is highly recommended not only for street use in the M3 but also in the most demanding and continous high rpm, high temperature, high abuse conditions! He explained many SCCA entries (and other forms of racing) are using it. And that the oil's film-strength, shear/tear properties, anti-wiping protection, lubricating ability, engine cooling, etc. are the best.
Keep in mind that the second number of an oil's viscosity grade (30 in this case) is the steady weight of the oil when at 100 degrees C (212 degrees F) and it compares with any other 30 weight grade oil, in thickness, regardless whether it's a 0W-30, 5W-30 or 10W-30. This is a A.S.E standard test which must be passed to be called a particular viscosity grade oil. (Don't let the "0W" verses the more common 5W or 10W confuse you.) This particular oil's ability to remain a 30 weight oil in very abusive engine temperatures at well over 150 degrees C (302 degrees F) allows it to be a strong and safe oil for street, strip and track.
He explained that using a heavier weight oil is not necessary or desired "unless" the engine is built losely (with wide bearing tolerances) which BMW's engine's are not. Also, he stated that car manufacturer's recommendations for using a heavier "petroleum" based oil such as 15W-40 or 15W-50 was only recommended because of the protection those petroleum weight oils could offer. Using lighter synthetic oils in lieu of hevier petroleum based oils offers "more" engine protection while also offering better wear protection too. It's a win-win situation.
Anyway, for those who have asked me about which oil I intend on using in my M3, I have made my choice!
Bob ///M3
WizzaMax's Avatar
I have used Amsoil for nearly ten years and was a dealer for a time...ready to go again for the discount..but can say the cars abd trucks ran great with confidence in the company and more knowledge given to their owners.
A little knowledge is a dangerous thing. Look into the facts, not hype...note the fact that you won't see Amsoil infomercials on late-night tv.
Old Apr 4, 2001 | 12:58 PM
got rice?'s Avatar
I'm another Amsoil user on this forum; 2+ years (hey, I'm only 21 LOL). In my younger years, I used Mobil One then switched over to Amsoil. The first thing I did when I picked up my 97 Miata was put in Amsoil 10w-30 in the engine and 75w-90 in the transmission and 75w-90 gear lube in the differential. I change the oil & filter every 6000 months because the car is competively raced in SCCA Solo I & II (12 Solo II races and 2 Solo I races annually).
I feel naked if I don't drive with Amsoil in my car. Shoot me an email if you're interested in signing up as a Preferred Customer (this gets you Amsoil products at dealer cost.. $10/6 months). I can send you the form to get you started.
Old Apr 4, 2001 | 01:06 PM
Maxwell's Avatar
[i]I change the oil & filter every 6000 months[/B]
WOW! That oil really DOES last!!
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
cruce91
Sep 20, 2015 10:23 AM
MaxLife17
Sep 8, 2015 02:36 PM
maxfever1987
Sep 6, 2015 06:20 PM
