Timing Chain
Old Aug 3, 2004 | 05:14 AM
Mr. Maxima's Avatar
Timing Chain
Alright when does this really "need to be changed" I have heard a lot of different opinions. Some say never, some say 60,000 miles.. I wanna get this stright..
Your thoughts..
Old Aug 3, 2004 | 05:32 AM
97maxxx's Avatar
i say dont change it unless it needs to be so only when its "squeeling" if there is no noise from it then it is fine that is what i have been told
Old Aug 3, 2004 | 06:27 AM
Kashoggio's Avatar
a chain wont squeel.... thats a drive belt. ITs true the timing belts should be changed areound 60l but the maxima has a timing chain, which does not require to be changed ever. There has been some problems where you might have to get it replaced but its very unlikely to do so. Most of the times you will have your timing chain guides go bad.
Old Aug 3, 2004 | 08:49 AM
askorbik's Avatar
It is a chain, so it does not need to be changed. It also says so on the user's manual. However, the belts need to be changed on a periodically.
Old Aug 3, 2004 | 09:24 AM
wunfstmax's Avatar
if you dont have any timing chain problems or related problems you wont need to change it...if you guides go bad they will replaced it most likely saying that the chain has been stretched, if you happen to have this problem stay away from nissan, itll cost about 4k to have them do it...my guides and tensioners were bad and got it done for 500
Old Aug 3, 2004 | 01:38 PM
Ant96GLE's Avatar
oh my god what retards, a timing chain does not have to be changed the way a timing BELT has to be changed. Timing Belts have a tendancy to stretch hence their 60K life span. Timing chains are much much harder to stretch and almost always last the lifetime of the car. If you have any issues with noise its most likely the tensioner and guides that go bad.
Old Aug 3, 2004 | 01:46 PM
Prophecy1's Avatar
I need to read the FAQ and IMPORTANT threads before posting a question
BTW you should go change the Timing Chain so you learn from your mistakes for not reading the damn FAQs ans Stickies
Old Aug 3, 2004 | 01:49 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
the timing chain is designed to last the life of the engine.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Oct 3, 2015 05:29 AM
trungg86
Sep 4, 2015 04:58 AM
Wareagle92
Sep 3, 2015 07:18 PM
