Knocking noise when I turn
turn your wheel all the way to the right, and lift the vehical. you will see a rubberish piece of material surrounding the inside of the axle. if you see oil around it, clean it up, and look for tears in the boot.
DAVE Sz, doesn't the strut bearing only make noise while you are actually turning the wheel? I thought that it simply allowed the spring to turn on the seat and the popping noise when turning the wheel was due to the springs hopping along since they can't turn on the bearing. I'm not sure about this so somebody please correct me if I am wrong. If this is the case then it would be the problem if it happens while at a standstill and turning the wheel, and it would be CV's if it happens when moving and turning in a circle.
pears
09-18-2015 05:25 AM
ballerchris510
09-11-2015 05:29 PM
