Clunk noise when turn wheel
Old Aug 6, 2004 | 01:06 PM
kash2776's Avatar
My 1995 SE makes a noticably loud clunking sound when I turn the wheel all the way to the left and move (like when making a U-turn). Does anyone have any idea what that could be. It was not there before. Could it be the tie-rod? Any way to check? Any help would be appreciated. Thanks.
Old Aug 6, 2004 | 02:22 PM
jt151's Avatar
CV Joint
Sounds like you're CV Joint
Old Aug 6, 2004 | 02:25 PM
datguyclark's Avatar
yea check and see if the cv boot is ripped..if it is..since is alreaady clicking you will need the whole axel..pep boys sells them for 100 bucks
Old Aug 6, 2004 | 03:12 PM
95_SE_5spd's Avatar
i got mine from napa for around 80 dollars
Old Aug 6, 2004 | 04:59 PM
kash2776's Avatar
It doesn't really sound like a clicking that an axle would make but more like 2 or 3 loud heavy clunks. Do you guys know if this is typical of a bad axle. I just rebooted and regreased them less than 20k miles ago when I replaced my clutch.
Old Aug 17, 2004 | 10:15 PM
MAXecutive's Avatar
I got the same problem on my 97 with 40,100 miles. When ever I make a left U turn or enter my driveway with the steering locked fully left, then I get one big bang and that it, not clicking like axles... I dont know what is it, only happens when fully locked left..???
Old Aug 17, 2004 | 11:07 PM
s0ber's Avatar
You got aftermarket springs?
Old Aug 18, 2004 | 12:05 AM
michaelnyden's Avatar
sounds like either improper wrapping of aftermarket springs or strut bearings...
Old Aug 18, 2004 | 03:32 AM
BLAZIN's Avatar
check your CVs first...then your springs and if both are good maybe a motor mount?...probably a cv joint though....i just got both mine replaced up front and a motor mount and a tranny flush...cost me $950 at the stealer w/ a discount.......wish i only had a lift
Old Aug 18, 2004 | 03:33 AM
BLAZIN's Avatar
*if only i had a lift
Old Aug 18, 2004 | 04:56 AM
Tyrexx's Avatar
yeah probly CV. + theres EDIT right over there --------->
Old Aug 18, 2004 | 08:48 AM
MAXecutive's Avatar
stock suspension, see that ugly a$$ wheel gap in my sig.
Old Aug 18, 2004 | 10:11 AM
nismology's Avatar
The clicking noise is typical of a bad outer joint while the clunking is typical of an inner joint.
Old Aug 18, 2004 | 12:02 PM
MAXecutive's Avatar
but I got only 40,000 miles on a 97 and about 70% of those miles are long distance highway milage. I dont get it...
Old Aug 18, 2004 | 06:14 PM
eturnl
I would say that this problem is your strut bearing, check this out:
http://www.motorvate.ca/mvp.php/703
Old Sep 7, 2004 | 02:11 PM
maximaman10's Avatar
I agree , a strut bearing
Old Sep 8, 2004 | 12:34 PM
Slo R1's Avatar
my 95 does it too i always thought it was just hitting the steering stops b/c i only hear it when i reach full lock.
Old Sep 8, 2004 | 12:56 PM
Brudaddy's Avatar
If it is the CV joint and axle....would you guys that have had to get a new one recommend doing this replacement yourself, or just pay someone to do it and be done?
I have a torn boot (which means a bad CV joint to follow) and I will be needing to do this soon. I figured I would just replace the axle while everything is apart anyway. I have 102k miles.
Old Sep 9, 2004 | 09:09 AM
piggpenn's Avatar
if you're gonna do it yourself, might as well replace everything while you're at it. if you're going to a mechanic, make sure they don't give you refurbished parts. My axles were replaced 2 times in less than a year because refurbished only lasts a few months if they're not that great.
Old Sep 9, 2004 | 09:24 AM
daveyg68's Avatar
I think this thread just solved my clunk clunk clunk problem. I have yet to make the repair, but it definitely makes sense. My noise sounds that a coil springs winding up, not a click click click of the CV joint going bad, even though mine are. Since I'm replacing the drive shafts in a week or so, I'll remove the struts and do the fix. Thanks for the great thread.
Old Sep 9, 2004 | 09:32 AM
Sy0p's Avatar
i just oreder 2 new cv boot kits for my car (it wasnt making any noise yet but the guy at goodyear told me that it would start. he told me it was $250 i was like **** U the cv boot kits are 10 bux on ebay and i can change em myself.
Old Sep 9, 2004 | 04:09 PM
Terran's Avatar
If it will do it while turning the wheel while not moving then it's a strut bearing.
Old Sep 9, 2004 | 04:53 PM
TrackSmart's Avatar
QUESTION: I also have the strut bearing issue. Do the strut mounts include the strut bearings? Or do I have to replace both separately?
If they are separate, then that's a lot of cash for little parts...
Old Sep 9, 2004 | 04:56 PM
Maximus_95's Avatar
my suspension also makes noise when turning left while accelarating. but weird thing is that it does not make noise when i put it into neutral. i hate suspension.
oh and btw, it started happening after the tein coilovers were installed. sucks!@
Old Sep 9, 2004 | 08:56 PM
eckohb's Avatar
mine does that, and its the upper strut mount on the passenger side. found that out when we swapped out my springs. gotta wait for adv. auto to get it in. only 36 bucks though, so not that bad at all
Old Sep 9, 2004 | 11:15 PM
TrackSmart's Avatar
So, should I be replacing my strut mounts AND bearings on a 1995 car with all stock stuff (I will be putting new struts and springs)?
Old Sep 10, 2004 | 11:17 AM
Terran's Avatar
Unless shipping is a whole lot, you can get OEM ones through JRnissan (use "maxima" promo code) for less than that. You may want to go that route since many have had problems with the KYB ones...don't know if other aftermarket ones would be any good, but I'd go with OEM's.
Justin Kroll
Sep 2, 2015 11:06 AM
maximusrising
Sep 2, 2015 09:55 AM
iflexsteel
Sep 2, 2015 08:04 AM
coasterswim
Sep 2, 2015 07:43 AM
carlosvq30
Aug 17, 2015 11:32 AM
