quick question. im lowering my car today
Old Aug 22, 2004 | 05:24 AM
gto400no1's Avatar
alright im lowering my car today but i still have to take a ride to home depot and get the rubber hosing for the springs. wut is this thing called so i know what im looking for. and if anyone knows in wut area i would find it in i would greatly appreaciate that too.
Old Aug 22, 2004 | 05:32 AM
Kevlo911's Avatar
Kevlo for President
I got mine at walmart in the AutoSection where the wireing/foglihgts are. It is called spiral wrap. I am sure you can find it anywhere that sells wires.
Old Aug 22, 2004 | 07:05 AM
jdm71488's Avatar
i dont mean to sound dumb, but what is that for?
Old Aug 22, 2004 | 08:24 AM
Terran's Avatar
It's so things don't squeek. Stock springs come with it as well as some aftermarket springs (H-techs do anyway).
Old Aug 22, 2004 | 09:30 AM
ThurzNite's Avatar
I went to the drinking water section, also the section with sprinklers and drip irrigation. I got clear drinking water tubing. It's much thicker and durable than wire loom (i dunno what rubber hose you're refering too). Here's what's on the label of the hose I bought
Clear Vinyl Tubing
10 feet
7/8" outside diamter
5/8" inside diamter (fits front Sprint springs snug... rear coils are smaller diameter)
Use for:
*low pressure
*food/water uses
*do not use with ice makers
You'll hafta get creative for the rears cuz the end of the coil is welded to the coil above it. I got mine snug. I had enuf tubing to do the tops of the coils too. good luck.
Jae
Old Aug 22, 2004 | 09:51 AM
Kevlo911's Avatar
Kevlo for President
http://forums.maxima.org/showthread....threadid=72678
Acording to that, the spiral wrap it better.
Old Aug 22, 2004 | 01:30 PM
ThurzNite's Avatar
Cool deal. The only spiral wrap @ my local hardware store was thin an weak, so I skipped it. Should work tho, and since it's spiral, easy to fit to any size spring.
Those who posted about vinyl tubing sliced through theirs (spiral and longitudinal) ... I didn't on mine. I tried that at first, but it sucked cuz it looked crappy, no matter how straight my cuts were, and if I sliced in sections, it just looked cheezy. So I measured the diameter w/calipers and bought the diameter I needed.
You can be creative with this stuff. I was gonna dip mine in the rubber stuff that you coat tool handles with... I may do that later.
Jae
Old Aug 23, 2004 | 01:11 PM
Kevlo911's Avatar
Kevlo for President
The spiral wrap is suppose to be thin and weak, its only purpose is to stop the noise.
Old Aug 23, 2004 | 01:27 PM
njmaxseltd's Avatar
Reuse the OEM spring isolators that are on your springs. They usually come right off and clean up for reuse on your sport springs. You can use some rubber cement to hold them in place on your new set of springs.
CRizz
41
Jun 7, 2021 05:42 AM
Lakersallday24
Jun 16, 2019 01:35 AM
twotonezed
Aug 16, 2015 08:10 PM
Trin1j23
Aug 12, 2015 08:31 PM
classymax420
Aug 6, 2015 06:35 PM
